July 12, 2025, 08:17:45 AM *
Author Topic: Choosing new throttle cables - price differences  (Read 1703 times)
BOZ
« on: November 09, 2009, 01:32:12 PM »
Honda Direct Line Parts carries Barnett throttle cables for $46 each for the "push" and "pull" cables. They also carry Motion Pro cables for $30 each. Does anybody know whether the less expensive Motion Pro cables are just as reliable as the Barnett cables? If not, then what is it that makes the Barnett cables worth more money? They are both stainless steel with clear coating. Would appreciate comments from anyone having experience with these cables.
F6MoRider
Lakeland, FL
« Reply #1 on: November 09, 2009, 02:14:30 PM »
Bought a SET of Barnett Stainless Steel Throttle cables (push & pull-set code 17810SC/17811SC) from http://www.phatperformanceparts.com/ for $83.95 in August.
No shipping and no tax (bought a K&N AF as well).  The cables seem to be about an inch longer than the OEMs but work fine.
I'm in Florida and find Hal's prices slightly more expensive on some things than some out-of-state locations, especially when considering tax and shipping.
Your results may vary.
Added:
Check out Barnett cables at http://www.hondapartsnation.com/pages/catalogs/viewproductdetailbysku/U2t1U3RhcnRzOmNhYmxlcw==/1/49794/barnett-stainless-steel-throttle-cables.
I just found www.hondapartsnation.com ($140) which had the exact same OEM parts list as I had at HDL ($180) but were $40 cheaper than HDL.  In addition, only $18 shipping v. $32 with HDL, but they are in MI and charge tax if you are also in MI.
« Last Edit: November 09, 2009, 05:43:05 PM by F6MoRider » Logged
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: November 09, 2009, 02:52:24 PM »
I've had Motion Pro cables on my 1100 Shadow ACE Tourer.  The clear protective coating turned brown due to sun damage.  I read in a recent m/c magazine that has a real mechanic writing their tech section to use sunblock on the clear coating to keep this from happening.  I've also talked with Valk owners that use Barnett cables who said they haven't had that problem.  If I were you, I'd pony up the extra coin for the Barnetts.
woefman
Arizona
« Reply #3 on: November 10, 2009, 10:10:15 PM »
Directline Gouges you Dang
Thanks for heads up Link on Honda parts nation    angel
Example Windshield
Honda Nation $211.98
Directline  $251.04
Nearly $40 bucks diff
I could by Synthetic Oil, a  Filter and Gas with the savings. cooldude
Spread the word we need to abolish these price gougers. police
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
