November 14, 2025, 02:00:30 PM *
Author Topic: Does anybody know..........  (Read 1325 times)
« on: July 10, 2018, 07:18:43 PM »
If the C Clamp trick will work to change out the valve stem on the rear tire?
« Reply #1 on: July 10, 2018, 07:29:40 PM »
I very well should.
« Reply #2 on: July 11, 2018, 03:50:56 AM »
Yes if you have a big enough C-clamp a tire vendor at Daytona did it to mine a few years ago
« Reply #3 on: July 11, 2018, 04:23:04 AM »
Ten inch C clamp, I think... one size bigger than a lot of places sell...
You should use a little board or something between the sidewall
and the C-clamp's feet or you probably won't like how the
C-clamp treats your sidewall...
« Reply #4 on: July 11, 2018, 05:00:40 AM »
My reason for wanting to use the C Clamp is to avoid removing the wheel.
Do you think that it will still work with the tire and wheel still on the bike?
« Reply #5 on: July 11, 2018, 06:01:51 AM »
Yes it works with the wheel on the bike and the bike on the lift
Pete
« Reply #6 on: July 11, 2018, 06:27:53 AM »
I have done several on bikes, with one or two c clamps, which ever works for you.
As the picture shows with 2 boards.
I use 1 small board with an angle cut to slip under the rim.
« Reply #7 on: July 11, 2018, 10:54:53 AM »
da prez had his little whizz bang bead breaker at I-16 and did a rear tire bead break for changing out a valve stem. Wheel DID stay on the M/C. He had modified a 10" C-clamp with some flat metal on the end so as to NOT tear up the tire when breaking the bead. You Do NEED Something under the round clamping areas to help prevent tire damage. RIDE SAFE.
« Reply #8 on: July 11, 2018, 12:57:58 PM »
I had a new stem put in using a C clamp.
Paladin528
« Reply #9 on: July 12, 2018, 06:32:12 AM »
Until I went all Steel I replace my stem at every tire change.  Never had a problem.  If your installer doesnt do this, find a new installer.
« Reply #10 on: July 12, 2018, 10:23:56 AM »
Honda recommends replacing the stem every other tire change.  If you do that you will likely not have a problem with the OEM stems but they generally cost about eleven dollars each.  The all steel stems can be had for a little over two dollars each and never need to be replace, well, not in this lifetime.
To me that's a no brainer.
jabster
« Reply #11 on: July 12, 2018, 10:32:42 AM »
35k miles. 1998 Tourer.
Maybe I should change my stems.
-john
Paladin528
« Reply #12 on: July 20, 2018, 08:09:18 AM »
I paid $1.49 each for my valve stems when I replaced the tire.  Thats a no brainer.  My installer deflates the tires by ripping the old stem out.  Mind you these are not the direct OEM from Honda but are OEM equivalent 90 deg stems.
I went all steel two tire changes ago and have never worried since.  I do keep 2 spares in reserve.
