November 14, 2025, 03:44:46 PM *
Author Topic: ?? for Darksiders...............  (Read 1435 times)
« on: July 13, 2018, 11:40:48 AM »
What tire do you run and why?
Daniel Meyer
The State of confusion.
« Reply #1 on: July 13, 2018, 12:55:42 PM »
Currently running a V rated 205/60R-16 YOKOHAMA AVID ENVIGOR...because it's affordable and I like it. Smiley
CUAgain,
Daniel Meyer
NewValker
VRCC# 36356
Oxford, MA
« Reply #2 on: July 13, 2018, 01:09:24 PM »
Hey Mark, ATT, almost 30k on it, no complaints, hasn’t lost a pound of air in 3 years.
Craig
Turns out not what or where,
Avanti
Stoughton, Wisconsin
« Reply #3 on: July 13, 2018, 01:21:03 PM »
Yokohama Avid Envigor 205/60/16 92v 1389 lb load limit vs Avon 180/60/16 rear  80H 992 lb load limit.
I run two up on an Interstate and have a rear carrier with light bar that attaches to the rear on which I carry 48 lbs of gear.
Carrier filled, saddle bags filled, trunk filled, trunk rack loaded and two riders we tip the scales at 1230. I am not interested in risking or wondering if I am over loading a tire at highway speeds in the heat. I like the ride, the traction for stop and go and tar snakes diaper. Life span is a plus.
« Reply #4 on: July 13, 2018, 01:29:41 PM »
Champiro VP1. Nicely rounded shoulders.
2KVISRiderDan
Valrico, Fl.
« Reply #5 on: July 13, 2018, 08:49:26 PM »
Kumho Ecsta PA31 195/60/R16 because that is what was on it when I bought it. This is my first experience with a CT but didn't take long to get used to.
2005 Yamaha Midnight Star SOLD
1997 Yamaha Royal Star Std SOLD
2000 Blue & Grey Interstate
2001 Black & Champagne Solo Interstate
1998 Blue & Cream Valkyrie Standard Roadsmith Trike
1997 Black Standard
« Reply #6 on: July 13, 2018, 10:06:52 PM »
Radar RV5 195/65/16
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #7 on: July 14, 2018, 03:58:28 AM »
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #8 on: July 14, 2018, 04:08:21 AM »
here is thread for the GT fit I use. http://www.valkyrieforum.com/bbs/index.php/topic,90637.0.html
pictures are gone due to photostash.
 keeping the tread width of the CT close to the OEM size is key.  the 205/65 lower rpms by 200, nice 2 mpg increase.  the taxi tire lowers rpms even more and is narrower. there are a few other brand tires on tire rack that are same tread width as the TT in the 205/65 size.
« Last Edit: July 14, 2018, 05:29:42 AM by 98valk, (aka CA) » Logged
« Reply #9 on: July 14, 2018, 05:24:20 AM »
« Reply #10 on: July 14, 2018, 08:26:32 AM »
I like the Taxi Tire plenty.  My only recommendation would be stay with good 13" shocks if using this tire, OEM or otherwise.  I'm using HD 444s.
« Reply #11 on: July 14, 2018, 08:36:09 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,90404.0.html
« Reply #12 on: July 14, 2018, 11:19:48 AM »
Austone Taxi tire and-YUP-I WILL purchase another when I git this one worn out. RIDE SAFE.
bikerboy1951
Grand Forks, ND
« Reply #13 on: July 14, 2018, 12:56:38 PM »
So lots of different choices.  Which one if any is the same size height-wise as the stock size tire. Or which tire is the closest to the stock tire.
« Reply #14 on: July 14, 2018, 05:51:17 PM »
The 205 60 16 is considered the closest to stock size (though 180 to 205 seems not close), but the height of them is nearly identical.
The Austone is a 175 vs OE 180, but it is a lot taller.
