March 30, 2026, 03:57:18 PM *
Author Topic: Modified Harbor Freight Tire Changer  (Read 495 times)
Alberta Patriot
« on: July 19, 2018, 08:20:45 AM »
About 3 years ago I picked up a "HF" car Tire Changer and modified it for  Motorcycle Rims using a 13" trailer rim(inner side up) as a grippy and stable mounting surface for the bike rims. I removed the upper portion of the tire changer above the round plate and inserted a 3/4" threaded rod coupler nut into the opening with gorilla tape wrapped around it until it was snug and used several self tapping screws to secure it:
I then drilled holes in the round plate to line up with the stud holes in the trailer rim and used a 3" ABS Pipe Coupling as a spacer between the plate and rim and bolted it all together. The small self tapping screws you see top and bottom were used to center the coupling:
I use a 3/4" threaded rod with another coupling nut and the rubber donut and large washer shown to secure the bike rim  against  the trailer rim which has a rubber laundry hose split down the middle and siliconed to the trailer rim acting as the grippy surface as well as bike rim protection:
« Reply #1 on: July 19, 2018, 08:32:48 AM »
Pretty fancy floor for a garage!  Grin
Alberta Patriot
« Reply #2 on: July 19, 2018, 08:39:57 AM »
Yep...the good wife knitted slippers for the cars and bike cooldude
« Reply #3 on: July 19, 2018, 09:17:10 AM »
I don't have pictures but Jerry (Bigwulf) of TN built his own version and it fits into a 2" receiver hitch on the back of a cage.  We used it the last time I swapped Auston Taxi Tires on my fat lady, it worked like a charm.
I love innovative ideas.   smitten  Thanks for posting yours.   cooldude
Alberta Patriot
« Reply #4 on: July 19, 2018, 09:33:42 AM »
This one is bolted down with flush drop-in anchors so when the tire changer is stored or not in use the fasteners are flush and not in the way as a tripping hazard. You want the changer some distance from walls for your tire iron:
https://www.homedepot.com/p/Simpson-Strong-Tie-1-2-in-Dia-Drop-In-Internally-Threaded-Anchor-DIA50P1/300572130?MERCH=REC-_-PIPHorizontal2_rr-_-205312356-_-300572129-_-N
