April 30, 2026, 08:34:20 AM *
Author Topic: Torq Loopz install pics?  (Read 3234 times)
pago cruiser
Tucson - Its a dry heat
« on: July 20, 2018, 08:42:59 AM »
Did anybody who has done this taken any pics?
I curious to see the clearance from the tire; the stock cat exhaust cross-over clears the tire by about 2". I'm playing with some stuff, and now have about 1" clearance from the appx 500F (or more) cross-over. Shocked
I believe the Loopz open up this area completely?
While there are some pics on the GL1800 site, our exhausts (I believe) are a bit different.
TIA
bscrive
Ottawa, Ontario
« Reply #1 on: July 20, 2018, 02:12:21 PM »
Here you go Mitch.
There is just under 6" from the Torq Loopz pipe and the tire.
pago cruiser
« Reply #2 on: July 20, 2018, 09:15:28 PM »
Thanks Brian!  Just what I was looking/hoping for.
Has your install worked out well since you did this?
Any recommendations on the install?  Some folks on the GL1800 Forum have had install issues re: getting it to seal, and stay sealed.  I saw one guy gave up with bolts and clamps and just welded them on!  That'll fix it!! cooldude
« Reply #3 on: July 21, 2018, 06:42:38 AM »
Brian how do you like them?
I have seen all the articles on the Wing forums and decided probably not go that route since I do like the crossover pipe. Honda knows pretty well how to design this bike and and Im not so sure I want to change that design. So I may buy another used exhaust and modify that.
bscrive
Ottawa, Ontario
« Reply #4 on: July 21, 2018, 06:35:27 PM »
Guys, I have been running them for two seasons and I love them.  When I first put on my Rush pipes last year they sounded great up until about 3000rpm.  That is when the droning sound would start.  I ignored it at first and then I broke down and got the Torq Loopz, because guys said that they eliminate the droning.  They do as advertised.  My bike now sounds like a Ferrari when I take off and quiets down significantly when I level out my speed.  I have been up to 85mph for extended amount of time without any issues.
I have not had any issues with them not sealing.  I suspect that that is from guys that don't clamp the pipes at the joints first before they mount them to exhaust hanger.  I have had them off and on a few times without any issues.  Mine have not leaked as of yet.
The main thing to remember when installing them is not to tighten anything up tight until you have everything in place.  The hardest thing for me was to make sure that the exhaust shields were in the right position.  Also, make sure that the end of the pipes line up even.  I was lucky with the right side.  Everything lined up perfectly.  The left side had me saying a few colourful words.  I was using aftermarket pipes being held up by brackets that I made myself.  Getting them lined up was a bit of a bitch.  Mainly because I bolted everything up tight.  uglystupid2
Robert, the crossover pipe really isn't needed.  I know Honda put it there, but it's only purpose is to even the exhaust pressure for a smoother sound. When I accelerate I can hear each side and I prefer that sound.  I would think that the guys at Torque Master Pipes would have included a cross over if one was needed.  Also, I have not noticed any decline in power because of it.  On the contrary, my bike seems to have more pick up and go, but that might be the Rush pipes, or my wishful thinking.  2funny
« Reply #5 on: July 21, 2018, 07:37:36 PM »
Thanks Brian
Not really unhappy with the stock exhaust but the cats do add heat even if there is no restriction. Glad your happy with the loops, I may get some but just haven't decided yet what Im going to do. Not really an emergency, and the thought of taking all the lower shields off is kind of slowing my motivation down a bit.    Grin
pago cruiser
« Reply #6 on: July 21, 2018, 09:34:33 PM »
Thanks again Brian.  cooldude
