April 28, 2026, 02:52:26 PM *
Author Topic: Wanted: Fork Bolts, aka fork caps  (Read 2770 times)
Disco
Republic of Texas
« on: July 22, 2018, 07:32:20 PM »
Figured I'd start here.  Does anyone have a spare pair of Valkyrie or VTX1800 fork caps laying around?  How 'bout a pair of forks that are too ugly or bent up to use?
While working to rebuild the forks on the rescue Interstate, we found that 1) judging by the color of the oil, they had been serviced recently, and 2) whoever replaced the caps must have used an impact wrench on them.  (they only require 37 or 41 foot pounds, depending on which page you look at in the service manual)  The result of the previous work was rounded hex heads and ridiculous tightness.  While removing the RH cap, the 24mm hex rounded off.  We hammered a 23mm on in its place, that worked and the fork was rebuilt, but it needs a new cap.  While attempting to remove the LH cap, it too rounded off.  We hammered the 23mm on it, but we still could not remove the cap.  My next step will be to Dremel a slot in the head and use an impact blade, but it will need a new cap, too.
Thanks!
Dave
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #1 on: July 22, 2018, 08:05:35 PM »
Dave, Dave, Dave, did you forget to loosen the pinch bolts?   Evil
Disco
Republic of Texas
« Reply #2 on: July 22, 2018, 09:26:34 PM »
Forks were out of the trees.   Sad
78 CB550K, 07 Helix
71 MT50 Trailhopper
RainMaker
Arlington, TX
« Reply #3 on: July 24, 2018, 08:01:57 AM »
If it's already boogered up, use a pipe wrench.  It will bite into the aluminum and give you the leverage needed.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
franco6
Houston, TX
« Reply #4 on: July 25, 2018, 11:16:07 AM »
Dave did you try a heat gun or torch? cooldude
Enjoy the ride!
godfire
Republic of Texas
« Reply #5 on: July 25, 2018, 04:21:33 PM »
Damn! Sounds like fun.... wish I was there!!! Cool
Ride Safe
Ride Often
Disco
Republic of Texas
« Reply #6 on: July 25, 2018, 04:26:15 PM »
Not yet, but I've gotten up to a 24" pipe wrench.   tickedoff   I'll stay away from a torch as I have PB Blaster trying to soak in, but the heat gun deserves a shot.
We wish you were here, too!   Smiley   How are things, Jim?
78 CB550K, 07 Helix
71 MT50 Trailhopper
Disco
Republic of Texas
« Reply #7 on: July 27, 2018, 09:54:43 AM »
Short version:  No success removing LH fork cap.   Sad   Angry   Valkpilot to the rescue with an extra pair of forks!   angel
Long version:  Before escalating, I gave the pipe / strap wrench approach one more session, this time with 2 strap wrenches, with the only tangible result being a broken strap wrench.  Next, I gave the cap an overnight dose of PB Blaster.  I didn't think it would help, but it couldn't hurt.  Next, I cut a slot in the rounded head and used the impact blade.  (I learned it's actually a steering linkage adjustment tool.)  It's not really impact duty, but it is certainly harder than the fork cap.
No good luck.
Next, I drilled two half-inch deep F bit holes, tapped them with a 5/16" - 18 tap, ran two bolts in, placed the fork in a vice wrapped in a rubber mat (really big strap wrench)and put the 24" pipe wrench on them.  I used constant and momentary pressure with the only tangible result being a bent 5/16" bolt.  Then, I broke out the heat gun.
No good luck.
At this point, I believe the threads are galled.  Even if I were to eventually remove the cap, I'm almost certain the tube will not be useable.  Sad to know that careless reassembly has claimed another good part.
78 CB550K, 07 Helix
71 MT50 Trailhopper
RainMaker
Arlington, TX
« Reply #8 on: July 28, 2018, 05:49:13 AM »
Wonder if they used loc-tite or some other glue on them?  If you ever get the cap off, you could retap the threads but there would still be doubt.  It's a shame.
2005 BMW R1200 GS
1972 CB500K1
