November 14, 2025, 03:25:18 PM *
Author Topic: Replacement for pin plug on reat caliper  (Read 1018 times)
slythern12
Fayetteville Ar.
« on: July 23, 2018, 10:03:46 PM »
I'd like to do something else besides the pin plug on the rear caliper. It tightens up over time and hard to get out with a screwdriver without damaging the head and I don't need it stuck in there. anyone ever replace it with a bolt so you could use a socket? I figure i'd have to cut one off to get one short enough. Thoughts?
« Reply #1 on: July 24, 2018, 02:02:42 AM »
Ive not done it,but, if you take it to a Ace hardware store or like place, you probably could match it up with a Allen head plug.
« Reply #2 on: July 24, 2018, 03:23:44 AM »
Next time you get one out, put anti-seize on it before you put it back in. No
problems after that.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: July 24, 2018, 03:58:50 AM »
If you use a proper JIS screwdriver, the slot won’t booger up nearly as easy.
« Reply #4 on: July 24, 2018, 04:00:55 AM »
This^^^^^
« Reply #5 on: July 24, 2018, 06:15:26 AM »
That plug is a 10mm X1.0 pitch. Very rare size. Just use NeverSieze when reinstalling.
« Reply #6 on: July 24, 2018, 06:39:19 AM »
I bought some stainless steel Allen head plugs a while back. I believe I have some extras. If you send me a pm with your address I can send you some. Might be a few days. I don't get back home till Friday.
« Reply #7 on: July 24, 2018, 07:57:19 AM »
If my memory serves me, what some have done is by a stainless steel socket head screw of the appropriate diameter, cut threads into the outside of the screw head, and cut off the screw shaft.  I use anti-seize on the OEM plug.
I would suggest taking meathead up on his offer if you can't find them locally.
I wasn't under them impression that a JIS screwdriver makes a difference for flathead-drive screws.  Phillips-style yes, like for the brake fluid reservoir screws, but a the interface between a flathead screwdriver and screw isn't that exacting.  Cool  Just use the biggest blade that easily fits the slot.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #8 on: July 24, 2018, 09:35:05 AM »
My hamfisted self can tell a big difference in the two. No slop at all with a JIS flathead.
Dusty
Mill Bay B.C.
« Reply #9 on: July 24, 2018, 03:02:41 PM »
I used Anti-seize and snugged the locking screw instead of tightening it and when I took it out two years later it was so tight I had to use a heat gun on the caliper to get it to come free. Aluminum and steel and water is not a good combination.
 Dusty
