February 14, 2026, 02:26:50 PM *
Author Topic: What didn't I do - Timing Belts  (Read 1630 times)
DarkSideR
Pueblo, Colorado
« on: July 27, 2018, 11:15:03 AM »
I had my Pulse Signal Generators go bad, and had replaced them.
Before taking everything apart I turned the crank to T1,2 & noted both cams were on the marks with "UP" reading correctly. I only removed the right side timing belt.
I replaced the Signal Generators, put the timing belt back on, and set the tension. Hand turned the motor and double checked the marks. Fired up the bike to find at idle all was well, however upon any RPM's above idle there is a noticeable sound coming from the right valves. Sounds like the valves are out of adjustment, but I know that isn't the case having recently done them.
What didn't I do?
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
« Reply #1 on: July 27, 2018, 12:39:57 PM »
What didn't I do?
Did anything turn at all while the belt was off?  For sure I'd do. Compression test.  Compare left to right
« Last Edit: July 30, 2018, 04:57:11 AM by Chrisj CMA » Logged
« Reply #2 on: July 27, 2018, 03:11:13 PM »
It's easy to install the belt one tooth off and not notice it. Pull the belt cover again and double check it. Recheck the bolts for the pulse generators and belt tensioners too.
DarkSideR
Pueblo, Colorado
« Reply #3 on: July 27, 2018, 03:15:48 PM »
Checked, checked, and double checked. Wondering if if I installed the generators switched. I did not pay attention when I took the old ones out. I use the longer lead for the bottom generator and the shorter lead for the top generator. Don't know if the bike would even run if they were switched.
VRCC#34410
VRCCDS#0263
ETC
« Reply #4 on: July 29, 2018, 08:15:44 AM »
Try running it with the cover off, that may reveal the cause
« Reply #5 on: July 30, 2018, 04:58:20 AM »
DarkSider. Did you ever figure out what happened?
Forge
San Antonio, TX
« Reply #6 on: July 30, 2018, 06:13:10 AM »
Following.
DarkSideR
Pueblo, Colorado
« Reply #7 on: July 30, 2018, 06:24:54 AM »
No. I rode it to church yesterday. Idles and runs fine, but the noise coming from the right side of the engine is bad. Loud enough to hear it in my helmet at 55mph.
I am borrowing a compression gauge today, and will compare the right cylinders, to the left.
I have remember something, something odd happened when I took the belt off. I got the timing marks lined up, removed the tensioner wheel, and removed the belt. Then Cam wheel then spun, like it was pre-loaded. The wheel spun maybe 20 degrees, and I had to use a lever to spin it back. It happened quick, and was reset quickly so it escaped my mind.
I'm pretty sure I have a bent valve  Cry
VRCC#34410
VRCCDS#0263
Cracker Jack
« Reply #8 on: July 30, 2018, 07:30:10 AM »
If it idles and runs fine, I'd say it's unlikely you have a bent valve. cooldude
P. S. The cam movement was the result of a valve spring(s) pushing on a cam lobe(s). There's just not enough force exerted by the spring(s) to bend a valve. cooldude
« Last Edit: July 30, 2018, 10:01:14 AM by Cracker Jack » Logged
« Reply #9 on: July 30, 2018, 08:58:58 AM »
If indeed it only turned 20 degrees then I agree it’s unlikely that was enough force to bend a valve. 20 degrees is roughly the travel from one pair of valves to the next. If to turned a bit more than that then it went totally past at least one valve and good chance of damage. The sound you describe is that of a bent valve.
Stop riding it in case the valve breaks off and does worse damage
« Reply #10 on: July 30, 2018, 02:47:49 PM »
More likely the compression in the cylinder. Remove the plugs first, before setting it to the timing marks.
Redline +
Northwest Washington
« Reply #11 on: July 30, 2018, 09:26:52 PM »
Pressure in a cylinder could possibly cause the crankshaft to move once the belts are removed but not a camshaft. As stated earlier, most likely spring pressure on a cam lobe causing the cam to move.
Redline
DarkSideR
Pueblo, Colorado
« Reply #12 on: August 01, 2018, 11:42:54 AM »
The plot thickens.
I was finally able to do a compression test today. Here's the results.
Right Bank (the side making noise)
#1 = 145psi
#3 = 150psi
#5 = 141psi
Left Bank (the side left alone)
#2 = 145psi
#4 = 141psi
#6 = 146psi
All within 10psi of each other.
So that's a positive 100% that I'm NOT dealing with a bent valve?
VRCC#34410
VRCCDS#0263
knockdolian
« Reply #13 on: August 01, 2018, 11:50:59 AM »
The cam shaft would be set with some valves on that bank open, under pressure. If the belt is taken off and the cam isn’t secured the valves will spring shut causing the cam to move. Check tapers again I’d say.
