February 14, 2026, 02:27:05 PM *
Author Topic: Looking for torque spec on the 24mm large fastener for the shock.  (Read 884 times)
mello dude
Dayton Ohio
« on: August 04, 2018, 06:22:40 PM »
Hi - i am looking for the torque spec on the combination fastener on the front end of the fender rail.
Not the shock bolt down spec, but the spec for the large 24mm nut. There is 2, one on each side and they bolt into a cross frame tube. That bolt in turn is the mount for the upper end of the shocks.
I am finding 20 ft-lbs in the FSM but that seems too wimpy... I am thinking it should be something like 32 ft-lbs.... -- I could be blind in the manual but I looked the body section and the shock area.. no go yet.
Thanks in advance.  Cool
Found it - 47 ft-lbs...
« Last Edit: August 05, 2018, 09:22:30 AM by mello dude » Logged
