April 30, 2026, 09:50:43 AM
1800 Tech Board
Brake/clutch fluid change question
Topic: Brake/clutch fluid change question (Read 2714 times)
Adirondack Bill
Upstate New York Near Lake George
August 08, 2018, 12:36:52 PM »
I have only done a brake/clutch fluid flush once before on a previous bike but I am going to give it a try with the Valk. I see on various sites they have both regular and synthetic Dot 4 fluid. I am sure our bikes came with conventional fluid, but I would like to go with synthetic. I know you can't mix regular and synthetic Motor oil together, but since I plan on flushing out most of the old fluid anyway, is it ok to switch to synthetic?? Also, about how many ounces will I need to flush front/Rear brakes and the clutch?
Re: Brake/clutch fluid change question
August 08, 2018, 07:06:32 PM »
As long as its not 5.1 fluid you are good to go and technically all brake fluid is synthetic. Its Glycol based absorbs water and removes paint.
Valkyrie0002
Fredericksburg, Va
August 09, 2018, 05:21:41 AM »
What Robert said. As long as it is DOT4 you are good. Cover the body panels and watch for drips. Don't get any on the pads or rotors. If you do, hose them off w/ brake cleaner.
Be sure to tighten the caps on the reservoirs good.
Been riding since about 1985. 1st bike was a CB900F then 88 CBR1000 , 1990 VFR750F and 94 CBR1000F. I bought my 2000 Std. Valkyrie new in 01. Was an MSF Rider Coach for 12 years. New owner of a 2014 Valk, Red, Non ABS.
Adirondack Bill
August 09, 2018, 06:33:09 AM »
Does anyone know about how many ounces are needed for a brake/clutch flush?
August 09, 2018, 07:33:08 AM »
Get 2 pints and probably return one
