February 14, 2026, 02:27:15 PM
Fuel on Intake valves?
Topic: Fuel on Intake valves? (Read 799 times)
Large
August 08, 2018, 05:53:48 PM »
I was changing my jets from 105 back to 100. Was running very rich and I noticed about a teaspoon or so of fuel on the intake valves. Only fuel on the left side valves I have replaced the float needles when I cleaned the carbs. I also had changed jets 38 slow and 105 mains. The petcock was rebuilt at the same time. Is this normal? I am worried about hydro lock (Btw I have a 99 IS with 15000 miles pigs cut, Ect mod and stock airbox and filter
Last Edit: August 09, 2018, 03:24:47 AM by Large
pancho
Bonanza Arkansas
Re: Fuel on Intake valves?
August 08, 2018, 07:00:19 PM »
Keep your petcock working correctly and debris out of your fuel tank and with new needle valves in the carbs you should be good to go for quite awhile Large.... I check the function of my petcock whenever the tank is off.
