November 14, 2025, 11:17:59 AM *
Author Topic: VALKORODO, I/S LED Headlight adj. Question  (Read 1152 times)
gregk
Retired
Chippewa Falls, wi.
« on: August 13, 2018, 07:33:55 PM »
I bought the lights like you mentioned on E bay and the mounting is not clear. So I need a bit of help please.    Mark on lamp was way off to the side on both lamps which don't look right .   I assume for the I/S the mark on the lampneeds to align with the center mark on the ring and the tab on the ring, correct ?
 Or the lead lights need to be pointing up an down not side ways right ?
 I plugged one in and what a difference over stock lights.
« Reply #1 on: August 13, 2018, 09:12:12 PM »
Having a hard time understanding the question.  Are you trying to fit the bulb into the reflector housing or trying to adjust the beam angle of the bulb?
If you mean fitment are you taking about the (three) tabs?  To make an H4 bulb fit in an Interstate, you need to remove (or clip) the two bottom tabs on the bulb.
If you mean alignment, I held the old halogen bulb next to the new LED bulb and it it was apparent how to adjust the bulb.  Yes up and down, not sideways.  Use the tiny Allen wrench supplied to adjust the beam angle.  It is straight up with the top hash mark.  I'd go take a picture right now but my bike is in town with BigBF at a lot I rented for him and his Aussie.  Yes quite a difference over stock!  Holy cow!
gregk
Retired
Chippewa Falls, wi.
« Reply #2 on: August 13, 2018, 10:37:01 PM »
LEDs up & down was what I needed. I did compare it to the halogen and thought I had it figured right but wasn't sure and thought better to ask. Thankyou !
Motorider
Pennsylvania
« Reply #3 on: August 14, 2018, 04:14:06 PM »
Correct me if I am wrong. Dosen`t the Interstate have two adjustment knobs next to the headlight housing to adjust the beams up or down. If I am correct, that may be easier then using the allen wrench. I don`t know if you turn them clockwise or counterclockwise to lower the beam of light. Maybe someone can clear that up for me.
« Reply #4 on: August 14, 2018, 06:20:39 PM »
These are adjustable LED bulbs.  The knobs you refer to are for the "big" vertical (up and down) adjustments.  Once set, they shouldn't need further adjustment no matter what type of bulb you use.
The allen adjustments are on the bulb itself and are for fine tuning the horizontal (side to side) LED beam angle. This allows me to seamlessly match the beam "line" on both Interstate bulbs, so they look and perform like one big bright bulb.
« Last Edit: August 14, 2018, 06:31:50 PM by Valkorado » Logged
TexasDragon
Katy TX
« Reply #5 on: August 16, 2018, 07:35:14 AM »
Which lamps did you get ?
1999 Honda Valkyrie Interstate
1985 Honda V65 Magna
2005 Honda VTX
« Reply #6 on: August 16, 2018, 07:44:56 AM »
These here ones.    cooldude
https://www.ebay.com/itm/H4-9003-LED-Headlight-Bulb-FANLESS-Conversion-Kit-Philip-Lumileds-Luxeon-ZES/202357583089?hash=item2f1d73acf1:g:VvMAAOSw2idbO4nb
Found recent thread.
http://www.valkyrieforum.com/bbs/index.php/topic,102023.0.html
« Last Edit: August 17, 2018, 06:56:42 AM by Valkorado » Logged
« Reply #7 on: August 17, 2018, 07:47:02 AM »
Probably the greatest consideration when replacing the headlight bulbs in an Interstate is the heat. MORE LIGHT USUALLY MEANS MORE HEAT and the Interstate headlight case is plastic. There have been a few reports in this forum about problems that were heat related, specific to the Interstate headlight case.  Caution would be indicated.
« Reply #8 on: August 17, 2018, 08:42:27 AM »
No problems with these bulbs.
