April 30, 2026, 09:50:06 AM *
Author Topic: Clutch fluid bleed problem  (Read 3138 times)
Adirondack Bill
Upstate New York Near Lake George
« on: August 15, 2018, 09:55:54 AM »
Just got done flushing my clutch fluid, master cylinder full of fresh fluid. With the bleeder valve closed, when I pull in the clutch lever, I hear a gurgling air noise down by the front of the engine. Also, I can't  build up any pressure in the system by repeatedly pulling in the lever. Where can air be escaping from with the bleeder valve closed? Is the valve bad? This is the first time I have flushed the clutch fluid on the Valk, how can the bleeder valve be bad?
« Reply #1 on: August 15, 2018, 10:30:46 AM »
If you dont have any fluid leaking under the bike more than likely you have air in the lines. At some point you must have let the master run dry or sucked all the fluid out then refilled, which is the wrong way to do it. If you just open the bleeder pull the handle, close the bleeder and keep doing that eventually you will get the clutch back.
Once you get a bit of pressure, then close the bleeder, pump the handle a few times and with the handle held down open the bleeder, once all the fluid is out close the bleeder and repeat, all the time keeping the master full of fluid.
« Last Edit: August 15, 2018, 10:45:59 AM by Robert » Logged
Adirondack Bill
« Reply #2 on: August 15, 2018, 10:55:02 AM »
Robert, I was very careful to not allow  the master cylinder get low when I was bleeding the system. Also, there is no fluid leaking from under the bike.  I will have to wait for my wife to get home so she can work the lever while I handle the valve. I did both front and rear brakes with no problem.  Robert, thank-you for responding.
Valkyrie0002
Fredericksburg, Va
« Reply #3 on: August 15, 2018, 01:16:59 PM »
Are you sure you had closed the bleeder before the lever hit bottom or you may have let off the lever a little before closing the bleeder?
I always use a Vac pump.  The clutch on my 1500 Valk was not right after I flushed so I bleed it some more and it corrected.  I did not have a good seal on the bleeder the first time around and I'm certain I got some air in there.
« Last Edit: August 15, 2018, 01:19:13 PM by Valkyrie0002 » Logged
Been riding since about 1985.  1st bike was a CB900F then 88 CBR1000 , 1990 VFR750F and 94 CBR1000F.  I bought my 2000 Std. Valkyrie new in 01.  Was an MSF Rider Coach for 12 years.  New owner of a 2014 Valk, Red, Non ABS.
« Reply #4 on: August 15, 2018, 04:27:55 PM »
NO Problem, we are all here to help.
The bleeder does not have to be tight between bleeds just snug will do that will make things go easier.
In fact you can stick your finger over the bleeder hole when your wife is letting go of the lever, then take your finger off on the squeezing the lever. Works well and makes things go faster especially since you are just looking to move fluid and air out.
« Last Edit: August 15, 2018, 05:32:13 PM by Robert » Logged
Adirondack Bill
« Reply #5 on: August 16, 2018, 08:00:24 AM »
All is well, with my wife's help, I was able to bleed a little air out of the clutch line. Don't know how it got in there, I never let the fluid level get low in the master cylinder when I was flushing the system. Also, that air sound I heard when pulling in the clutch was a normal sound, I just never noticed it. Clutch fluid was 4 years old and was the color of urine, not clear like new fluid.  It is amazing all the crap you have to remove just to get access to the clutch bleeder. Thanks guys, and by the way, what the heck  is a EVAP canister?
Valkyrie0002
Fredericksburg, Va
« Reply #6 on: August 16, 2018, 08:35:28 AM »
EVAP canister is part of the emissions system, gas vapors.
« Reply #7 on: August 16, 2018, 09:50:56 AM »
Yes charcoal filled so the gas vapors from the tank go in there get trapped and when you run the engine those vapors get pulled into the engine and disperse. Sometimes also venting to the outside air but again processed through charcoal so you don't smell gas fumes.
