November 14, 2025, 11:17:57 AM *
Author Topic: Digital speedo  (Read 1185 times)
knockdolian
« on: August 24, 2018, 02:11:03 PM »
Hi all, having owned the Valkyrie for about 6 weeks now I have two complaints.
1, the stock headlight is absolutely poo. I recon a candle in there would work better. That I can sort with a new LED unit.
2, at night I can’t see the speedo. I’ve been using my sat nav as a speedo but tonight that refused to soldier so I had no idea the speed I was doing anywhere. Don’t worry my long range Visio is spot on.
Is there a GPS speedo that will fit the Valkyrie mount or a digital speedo available?
« Reply #1 on: August 24, 2018, 03:06:38 PM »
Honda traditionally makes the speedo read high. Indicated 75 is actually 70. 45 is 43. Just get use to it and save your money on a "speedohealer".  All 3 of my valks and my '05 wing have been the same.
« Reply #2 on: August 24, 2018, 04:54:17 PM »
Some have put led's in the speedometer and tachometer for increased lighting, if that's the issue.
knockdolian
« Reply #3 on: August 24, 2018, 11:57:37 PM »
My bike is a 2000, going by the sat nav it bang on. Just can’t see it at night. I’ll try the LED way first. Would rather have a big number readout.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #4 on: August 25, 2018, 05:31:57 AM »
I've used my "smarter than me" smart phone in a Ram X Wing mount while using a speedometer app check  speed when trying out a dark side tire.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Bone
« Reply #5 on: August 25, 2018, 06:11:51 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,34551.msg320539.html#msg320539
http://www.valkyrieforum.com/bbs/index.php/topic,40568.0/topicseen.html
These links will help you decide they are from 2012 & 2014 made my speedo easy to read at night.
Funbaldguy
grand blanc Mi
« Reply #6 on: August 25, 2018, 05:10:01 PM »
Very good posts.i ordered some. Glad to know it’s not just me cooldude
« Reply #7 on: August 26, 2018, 07:45:47 AM »
I replaced the instrument bulbs on all my valks with cool white LED's after trying the colors - they just don't work. I added a pot on my road bike "Jade" so I can set the brightness from zero to very bright.  Very useful that way. Remember the polarity matters on LED's so you have a 50/50 chance of inserting it right the first time. This bulb: https://www.superbrightleds.com/moreinfo/wedge-bulbs/194-led-bulb-5-smd-led-tower-miniature-wedge-retrofit-car/206/919/
