February 14, 2026, 07:56:31 PM
Testing radiator fan
Topic: Testing radiator fan (Read 1192 times)
retirednavy
August 27, 2018, 07:07:19 PM »
Hi is the a quick way to test and make sure my radiator fan is coming on? Thanks
sdv003
Prescott Valley, AZ
Re: Testing radiator fan
August 27, 2018, 08:26:47 PM »
First thing I would do is unplug the wire to the temperature switch that is in the radiator and ground it. Fan should come on.
Attic Rat
VRCC # 1962
Tulsa, OK
September 01, 2018, 05:50:10 AM »
SDV003 is correct ground the wire if the fan doesn't run ck the fuses. On an interstate there is a fuse box on the side of the fuse box and that is where you will find the fuse for the fan.
September 01, 2018, 06:35:44 AM »
Non-electrical-technician way to check: Ride through the wal-mart section of town
on a hot day, it should come on at one of the stop lights...
-Mike "hot days at stop lights is about the only time mine comes on..."
retirednavy
September 01, 2018, 07:50:46 AM »
Tested and all runs good thanks
