March 30, 2026, 10:11:52 AM *
Author Topic: Missing Vent(?) tube??  (Read 604 times)
Alberta Patriot
« on: August 31, 2018, 11:43:51 AM »
I am about to install the new Alternator and I found that a tube connected to the "T" that is shown in the pic. is gone. It was there when I removed the Alternator. The top end leads to the tank vent, the bottom leads under the bike with the other tubes down there. So where does the missing tube go??   Thanks
« Last Edit: August 31, 2018, 11:45:25 AM by 7th_son » Logged
« Reply #1 on: August 31, 2018, 11:57:21 AM »
I'm pretty sure there's no tube. That's some kind of vacuum break or some such...
« Last Edit: August 31, 2018, 11:59:48 AM by hubcapsc » Logged
Thunderbolt
Worthington Springs FL.
« Reply #2 on: August 31, 2018, 12:04:29 PM »
That's the way it was designed, kind of an anti syphon device.
« Reply #3 on: August 31, 2018, 12:05:52 PM »
Yup, there is no tube on there, it's fine as is.
Alberta Patriot
« Reply #4 on: August 31, 2018, 12:18:18 PM »
Thanks...I must be catching 'old timers disease'...coulda' sworn there was a tube connected there. Shocked
Sorcerer
Brooklyn Center MN.
« Reply #5 on: August 31, 2018, 07:47:25 PM »
That is the one that when a spider try’s to crawl in or you manage to get mud on the end of that T is when it takes you a week to figure out why the bike will only run for a short time. Also you want to make sure that you don’t kink that hose.
