January 30, 2026, 03:42:28 AM *
Author Topic: Power point for hidden antenna  (Read 2512 times)
BradValk48237
Oak Park, MI
« on: November 12, 2009, 09:53:10 AM »
Hi all,
 I have gone "Super Valk" on my 2000 I/S and have bought a hidden antenna that needs a switched power point. Where is the best place to hook it up?
B
Joe Hummer
Arnold, MO
« Reply #1 on: November 12, 2009, 11:11:23 AM »
The accessory plug under the right side cover is a switched power connection.  Fuse is also under the right side cover.
Joe
1999 Valkyrie Interstate
BradValk48237
Oak Park, MI
« Reply #2 on: November 12, 2009, 02:44:07 PM »
Thanks, thats what I thought, ws just seeing if there was any other place that might be better. Will use it.
B
Madmike
Campbell River BC, Canada
« Reply #3 on: November 12, 2009, 04:36:49 PM »
Don't know if it is possible with the Valk radio or if all of these style antennas do it but some that I have seen power up and down as the radio is turned on or off.
PAVALKER
Pittsburgh, Pa
« Reply #4 on: November 12, 2009, 05:18:40 PM »
Hi all,
B
How about some more info on your hidden antenna??? Considering a SV mod this winter..... care to share your project tips.
 Will it be in the back of the bike, you could tap off rear running light.
John
BradValk48237
Oak Park, MI
« Reply #5 on: November 16, 2009, 07:37:56 PM »
I should clarify...It is a amplified hidden antenna.....  small box on the end of the antenna cable, got it from AntennaX on ebay, $24. Needs 12v power to boost the signal. Will take pictures and post once I get it mounted. This way I won't need the stock antenna at all, wether the trunk is on or not. There are others that are to be mounted on the fairing, but I try this first.
B
