February 14, 2026, 07:56:29 PM *
Author Topic: Tires '98 1500 tourer  (Read 1124 times)
Drclassic
« on: September 04, 2018, 05:58:52 AM »
OEM tires call for radials-but Bias seem to be the choice for replacements-PROS and Cons appreciated
« Reply #1 on: September 04, 2018, 06:25:19 AM »
?? whose choice?
There's a ton of good radials that fit 1500s... Avon Cobras and Metzler me888s are
a couple of the popular ones...
h13man
Indiana NW Central Flatlands
« Reply #2 on: September 04, 2018, 07:41:44 AM »
Radials: 180/70R-16  150/80R-17
Bias: 180/70B-16  150/80B-17
As far as the OEM Bridgestone Exedra's are concerned, radials are all is offered. Now that being said I have a Vulcan 1600 that weighs 25 lbs. more than my "dressed" standard and it comes from the factory with bias ply. Why? I don't know but a lot "heavys" use radial tires. I'd stay with what the factory used/design fot the Valk's ride/suspension setup. If this would be your 1st. tire change I'd stay with the radials to determine the difference in ride with new tires. That alone is a night and day difference in most case. The wear factor between bias and radials, I just can't say as I respect that the manufacture knows best but....
« Last Edit: September 04, 2018, 07:43:20 AM by h13man » Logged
h13man
« Reply #3 on: September 04, 2018, 07:45:58 AM »
As far as the OEM Bridgestone Exedra's are concerned, radials are all is offered (701 front. 702 rear). Now that being said I have a Vulcan 1600 that weighs 25 lbs. more than my "dressed" standard and it comes from the factory with bias ply. Why? I don't know but a lot "heavys" use radial tires. I'd stay with what the factory used/design fot the Valk's ride/suspension setup. If this would be your 1st. tire change I'd stay with the radials to determine the difference in ride with new tires. That alone is a night and day difference in most case. The wear factor between bias and radials, I just can't say as I respect that the manufacture knows best but....
« Reply #4 on: September 04, 2018, 08:57:48 AM »
If you put bias tires on a car that calls for radials, you'll soon regret it. It won't track well over a varied road surface. IMHO Avon Cobras are the best tire for Valkyries. After 160K miles on Valks, I won't run any other tire.
Kokomo Kevin
Kokomo, Indiana
« Reply #5 on: September 04, 2018, 04:39:42 PM »
Second on Avon Cobras, had Dunflops and Metzlers went back to Avons. Near 100K on mine
« Reply #6 on: September 04, 2018, 05:50:40 PM »
OEM were Dunflops. At least on the two I bought.
Also  +1 on the Avons well over 100k. And still happy.
dconstruct55
Phoenix AZ.
« Reply #7 on: September 04, 2018, 05:57:12 PM »
Love the Avon Cobras, have a 200 on the rear and 150 up front. I'm with Sandy, I won't run anything else on my '99 Tourer or on my '06 Kawasaki Vulcan 2000 LT.
« Reply #8 on: September 04, 2018, 07:17:46 PM »
What do you mean seems to be the choice?
F6Dave
« Reply #9 on: September 05, 2018, 07:19:30 AM »
Here's another vote for Avon Cobras.
