February 14, 2026, 04:17:04 PM *
Author Topic: Speedo correction?  (Read 978 times)
Oldnick
Western Australia
« on: September 06, 2018, 10:08:26 PM »
I have put a lower profile tyre on the front of my 98 Valk standard and the speedo is now lower by a calculated 5%, based on tyre diameter ratios. Suddenly I get an extra 10Km out of a tankful.
It's just a nuisance and may even avoid speeding fines  cooldude, but I was wondering there is a way to adjust the speedo, either by adjustment or some sort of gearbox. If so, what sort of money am I looking at, to know if it's worth the worry.
I have seen a couple available, but they were specifically for diff ratio changes in specific cars.
Thanks for any advice.
« Last Edit: September 06, 2018, 10:15:14 PM by Oldnick » Logged
Nick
May God save us from believers!
9Ball
« Reply #1 on: September 07, 2018, 02:51:09 AM »
Your best bet would be a gps or smart phone app to show actual speed.  Based on how the standard and tourer speedo drive is made there isn’t a mechanical fix to this problem that I’m aware of.
The interstate has a different method that might be able to be adjusted using a “speedo healer” that I’ve seen on eBay.
Good luck.  I think a lot of bikes and cars overstate speed to give the impression of higher performance. I know my Subaru WRX STi used the maximum lawful allowable speed error for this very reason.  My Wife’s VTX1300 overstates speed by almost 5 mph at highway speeds using OEM spec tires.
Your case is different in that you altered the dimension of the front tire but the solution remains the same.
« Last Edit: September 07, 2018, 02:53:45 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
