February 14, 2026, 04:16:46 PM *
Author Topic: Custom Paint Part Removal Issue  (Read 973 times)
bpt518
Lake Mary, FL
« on: September 08, 2018, 05:09:07 AM »
Good morning,
I haven't been on in awhile and I am requesting some help.
I took my bike to get painted by a friend who does really good work, the issue is he could not get off the front plate where the key hole goes to release the seat. I believe he said there were 2 10mm bolts that he removed and it still didn't come off.
If anyone can help or point me the right direction, that would be great.
Thank you in advance.
« Reply #1 on: September 08, 2018, 05:12:10 AM »
The middle cover fits into a rubber grommeted slot at the bottom.  You'll need to remove the key cylinder first which has a push/pull device holding it.
https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500c-a-valkyrie/seat
#1 in this graphic.
« Last Edit: September 08, 2018, 05:14:26 AM by Hook#3287 » Logged
bpt518
Lake Mary, FL
« Reply #2 on: September 08, 2018, 05:23:28 AM »
Thank you so much.
« Reply #3 on: September 08, 2018, 06:49:03 AM »
Also be very careful putting it back. Tight squeeze and you could scratch your new paint. Ask me how I know Shocked
« Reply #4 on: September 08, 2018, 08:22:45 AM »
You also need to unplug the tip sensor that is screwed onto the cover.
