February 14, 2026, 06:01:02 PM *
Author Topic: coolant lamp  (Read 1053 times)
blacktrain
douglas,ma
« on: September 14, 2018, 05:25:25 AM »
hi, will the coolant lite come on key on engine off like the oil lite or only when there is a issue,looks like single wire to sensor so im thinking it will only come on when there is a problem. unlike oil lite on with key then off when running. thanks just want to be sure. 1997 valk ct, i installed after market tach and lites for oil pressure -stand-coolant
« Reply #1 on: September 14, 2018, 05:58:21 AM »
There was an extensive thread about this last week.  You should read.  Bottom line your temp light will not come on with the ignition if there is no problem.
You need to post a couple pictures of your tach mod
« Last Edit: September 14, 2018, 06:02:04 AM by Chrisj CMA » Logged
Brewer
Denver, CO
« Reply #2 on: September 14, 2018, 06:10:44 AM »
Here is a thread with good info and wire diagram
http://www.valkyrieforum.com/bbs/index.php/topic,102407.0.html
Brewer - it is a hobby
h13man
Indiana NW Central Flatlands
« Reply #3 on: September 14, 2018, 06:32:43 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,102921.0.html
blacktrain
douglas,ma
« Reply #4 on: September 14, 2018, 07:05:14 AM »
great will check it out ,thanks for the info
