March 30, 2026, 04:37:16 AM *
Author Topic: Paging Serk. Paging Serk  (Read 1677 times)
« on: September 14, 2018, 03:12:08 PM »
My FB and youtube video playback has gone doolally.
The video is zoomed in and magnified so all I see is about 10th area of the video but LARGE.
« Reply #1 on: September 14, 2018, 03:20:01 PM »
And videos embedded in web sites.  tickedoff
Netflix plays OK on the laptop.
« Last Edit: September 14, 2018, 03:21:34 PM by Britman » Logged
« Reply #2 on: September 14, 2018, 03:28:08 PM »
Nothing off the top of my head, about to head out to take a kiddo to swim practice, will be out for a few hours....
Tried different browsers? If using IE/Edge, try Chrome, or Firefox, same issue?
« Reply #3 on: September 14, 2018, 03:33:30 PM »
I'll check thanks.
Edge is messed up as well.
the only setting I changed recently was volume
« Last Edit: September 14, 2018, 03:36:19 PM by Britman » Logged
« Reply #4 on: September 14, 2018, 03:35:03 PM »
This is probably no help at all, but to make my viewing screens bigger or smaller, I hit control + or control - .
Maybe this only works with Firefox.
« Reply #5 on: September 14, 2018, 06:21:08 PM »
What Jess said. it works the same on a Mac but instead of the control key you use the command key.
On the Mac, to make the screen back to original size its Command key plus the zero key.  Don't know if its the same on a Microsoft PC.
« Reply #6 on: September 14, 2018, 06:46:52 PM »
Did some searching, finding a few examples of other folks with the same issue, but not good solid fixes, just some "This might work"s...
So in that spirit...
"I had the same problem but found my solution by experimentation. In my case It was the graphics card control. My machine has a new AMD Radion with an associated AMD Catalyst Control Centre (American -> “Center”). The menu path used was: Video; Quality; Video Demo Mode. Enable Demo Mode and select "Full screen mode (enhancements off)". I then clicked on apply. I experiment further by toggling between enabled and not and in each case the problem came back/went away."
Also, is this a laptop or a desktop? Crazy question if it's a laptop - does the same issue happen if you start playing a video when it's on battery vs. plugged in?
« Reply #7 on: September 15, 2018, 06:08:07 PM »
How does your brain work???
Laptop and when power is disconnected videos are poifect!
« Reply #8 on: September 15, 2018, 06:28:38 PM »
LOL! My wife says I have "The Knack." 99% of the time I don't even know why I think of trying some of the things I try...
Okay, let's try something else kinda whacky... While it's plugged in, assuming Chrome is your usual browser (If not I'll try to find the directions to do this in others)  Go to the settings page:
chrome://settings/
Scroll to the bottom and expand the "Advanced" section.
Under the "System" subheading look for an option that says "Use hardware acceleration when available"
Turn that off (The blue slider to the right)
(If it's off, turn it on, but I'm guessing it's on already)
Then go try some videos while it's plugged in.
« Reply #9 on: September 15, 2018, 08:46:46 PM »
Related to that query, here's a relevant video to test out with:
https://www.youtube.com/watch?v=Dx6HojLBsnw
« Reply #10 on: September 17, 2018, 01:37:56 PM »
You da man!
Thanks.
« Reply #11 on: September 17, 2018, 01:40:44 PM »
I found this using your information
https://www.techadvisor.co.uk/how-to/internet/how-turn-off-gpu-hardware-acceleration-in-google-chrome-3605455/
« Reply #12 on: September 17, 2018, 01:44:41 PM »
You da man!
Thanks.
Sweet, that fixed it then?
baldo
Youbetcha
Cape Cod, MA
« Reply #13 on: September 17, 2018, 01:50:01 PM »
chrome://settings/
How does something like that happen?
Daniel Meyer
The State of confusion.
« Reply #14 on: September 17, 2018, 02:26:46 PM »
Laptops themselves, and some applications, will adjust their performance or processing based on how much power is available...plugged in? Plugged in and charging? On a doc? (external monitor) Not plugged in? Not plugged in and battery below a certain %? All those things can change stuff. Even the detected capacity of the "brick" (power supply) can adjust stuff.
If part of the "stuff" isn't working correctly then you can see intermittent weirdness depending on the current "state".
That's a great catch Serk!
CUAgain,
Daniel Meyer
« Reply #15 on: September 17, 2018, 02:44:04 PM »
Ah ha. The laptop battery at one point got to about %15.
Daniel Meyer
« Reply #16 on: September 17, 2018, 02:56:35 PM »
Also google chrome just had a recent update...that could have changed something as well...
CUAgain,
Daniel Meyer
« Reply #17 on: September 17, 2018, 02:57:27 PM »
I denied that.
baldo
Youbetcha
Cape Cod, MA
« Reply #18 on: September 17, 2018, 03:12:35 PM »
I didn't know that. I've always assumed that as long as the laptop was plugged in, it was fully operational, regardless of battery charge.
« Reply #19 on: September 17, 2018, 04:08:13 PM »
It's more of a situation where if it's on battery it goes into power conversation mode, cuts back on the power.
(Geeky bit ahead)
Modern computers have both the CPU and a GPU as (Logically or physically) discreet processing engines. The CPU you're probably familiar with (Central Processing Unit) as the "brain" of the computer.
The GPU (Graphics Processing Unit) is high powered circuitry for rendering graphics.
Some tasks, such as playing back video, can be handled purely by the CPU or the GPU can ramp up and help with this task.
Using both the GPU and CPU for such a task however utilizes more power, so it would make sense in a power saving mode for the GPU usage to be scaled back.
Also, as we saw here, utilizing the GPU for such tasks can sometimes..... not work...
Tracking down bogus video drivers, Adobe Flash plugins, bad settings in the drivers, etc MIGHT fix it, but most of the time the simpler and easier fix is just to turn the hardware acceleration off, so that the video is rendered purely by the CPU, without utilizing the GPU.
(That's why when the laptop was unplugged the video worked, unplugging power acted similar to the steps I outlined for him to disabled the hardware acceleration in the browser.)
baldo
Youbetcha
Cape Cod, MA
« Reply #20 on: September 17, 2018, 04:26:25 PM »
(Geeky bit ahead)
« Reply #21 on: September 17, 2018, 05:53:16 PM »
(Geeky bit ahead)
Hey, you asked.  LOL.  (Read Serk's tagline)
« Reply #22 on: September 17, 2018, 06:02:08 PM »
Some folks believe the warning signs...
...other folks have to touch the electric fence for themselves just to make sure...  2funny
...and ya'll are lucky I'm kinda rusty... When I worked in an actual office whenever a PHB asked for a technical explanation, we'd use the 5 minute rule...
That's where we'd start explaining, in excruciating technical detail until their eyes would glaze over.
...and then we'd keep going 5 more minutes.
baldo
Youbetcha
Cape Cod, MA
« Reply #23 on: September 17, 2018, 09:48:21 PM »
LOLOL
You didn't need five minutes......
baldo
Youbetcha
Cape Cod, MA
« Reply #24 on: September 17, 2018, 09:49:44 PM »
(Geeky bit ahead)
Yer right.........but I've always been the guy that pushes the red button...... Grin
« Reply #25 on: September 18, 2018, 06:53:03 AM »
Just because I love analogies and pride myself on being able to transfer complex ideas to a form my audience can digest, let's try this:
CPU - Main turbine jet engine
GPU - Afterburner
Using the main turbine AND the afterburner will make you go faster, but consumes a LOT more fuel (Electricity on the computer side)
Using just the main turbine is more fuel efficient, so if you're in a fuel conserving mode (I.E. a laptop running on battery, or a plane trying to make it back to an airfield before fuel runs out) you don't wanna use your extra "Oomph" device, be it the afterburner or the GPU.
And in this case, there's something messed up in the interface with the afterburner, the nozzles for it are skewed to the side so that when the AB is lit up the plane pulls hard to one side.
So in that case the easiest fix is to remove the AB button from the cockpit so the pilot doesn't use it anymore.
(Not a perfect analogy, the GPU is still there for use by other parts of the computer, we just denied it's usage to Chrome, specifically.)
baldo
Youbetcha
Cape Cod, MA
« Reply #26 on: September 18, 2018, 07:04:30 AM »
GPU - Afterburner
« Reply #27 on: September 18, 2018, 07:20:03 AM »
PHB = ?Problem Having Bastard?
« Reply #28 on: September 18, 2018, 08:40:11 AM »
Pointy Haired Boss...
In reference to the PHB from the comic strip Dilbert...
RP#62
Gilbert, AZ
« Reply #29 on: September 18, 2018, 03:32:29 PM »
Speaking of which, did someone mention ....the Knack?
https://www.youtube.com/watch?v=g8vHhgh6oM0
-RP
« Reply #30 on: September 18, 2018, 03:59:21 PM »
-RP
Yup... Although your version is better and more complete...
« Reply #31 on: September 18, 2018, 06:11:35 PM »
-RP
Who said :The Knack:???
https://www.youtube.com/watch?v=g1T71PGd-J0
