February 14, 2026, 07:56:24 PM *
Author Topic: light problem update..  (Read 850 times)
six pack
Quispamsis New Brunswick, Canada
« on: September 17, 2018, 05:54:59 PM »
Back in the first of Aug. or there abouts I had signal light problems and it grew into headlight problems... well the headlight problem turned out to be PO mods to headlight that included BonS smart switch,  well we cleaned up any bad connections and rewired the relay on the smart switch, all  good, replaced turn signal switch ,, all good, removed rear fender section and found green ground wire had worked loose,, fixed that and all is well,   thanks for all the advise received on this problem.. much appreciated...    Smiley
