February 14, 2026, 06:02:18 PM *
Author Topic: Fuel leak  (Read 1233 times)
M.Kyzer
« on: September 20, 2018, 05:05:23 AM »
Went to ride the valk to work this morning but I could smell gas really strong. Had to use my phone flashlight to see but gas was pouring out behind the middle carb right side up under where I couldn't  see. Would start leaking  as soon as u turned the petcock on even with the bike not running. Any ideas where to start looking when I get home to find the leak.
« Reply #1 on: September 20, 2018, 05:45:16 AM »
I would start with the middle carb on the right side.   crazy2 2funny
Sorry couldn't help it.
Sounds like fuel rails. If I'd doesn't stop on it's own you're going to have to pull the carbs.
longrider
Vernon, B.C. Canada
« Reply #2 on: September 20, 2018, 06:52:51 AM »
How many days had the bike been sitting before you rode it. It takes a long time for the fuel rail o-rings to dry out.  Also if the fuel leaks when you turn the petcock on with the bike Not running,  the vacuum operation is not working correctly and needs a rebuild
M.Kyzer
« Reply #3 on: September 20, 2018, 06:58:55 AM »
Bike was parked only 1 week. Petcock was replaced about 2 months ago.
Bagger John - #3785
« Reply #4 on: September 20, 2018, 07:03:21 AM »
As Chris pointed out: Fuel rails. Specifically, the O rings used in all the joints.
Go to an online microfiche and order the required quantity of every O ring used in the carb assemblies then replace them while the banks are apart. If one failed, the others are probably right behind.
Roidfingers
Tuscaloosa, Alabama
« Reply #5 on: September 20, 2018, 08:21:36 AM »
I think redeye sells a kit.
https://redeye.ecrater.com/p/6738361/carb-fuel-rail-leak-kit
Daniel Meyer
The State of confusion.
« Reply #6 on: September 20, 2018, 08:36:30 AM »
Yep, sounds like fuel rails...
Also:
Was the petcock replaced with OEM? 'cause that's not working right if the fuel leaks right when you turn it on...
CUAgain,
Daniel Meyer
M.Kyzer
« Reply #7 on: September 20, 2018, 08:44:15 AM »
Yep OEM ....
Daniel Meyer
« Reply #8 on: September 20, 2018, 08:52:53 AM »
Yep OEM ....
Welp...ya need to test its functionality when you're got stuff apart to fix the actual leak.
-dm
CUAgain,
Daniel Meyer
longrider
Vernon, B.C. Canada
« Reply #9 on: September 21, 2018, 03:25:55 PM »
A month ago I purchased a new to me valk IS    Last week I removed the tank to install a new air filter.  Every time I remove the tank on on either of my Valkyries I check the operation of the petcock    The tank is set on a table with the petcock hanging over the edge just far enough so a hose Can be attached to the outlet. A catch container is used for the fuel.  A small length of hose is attached to the vacuum side.  Open the petcock. Nothing should flow.  Apply vacuum.  Fuel should flow.  Remove vacuum and fuel should stop.  Repeat a couple of times.  I always have a spare cover set In my parts bin
« Last Edit: September 21, 2018, 03:28:57 PM by longrider » Logged
Dusty
Mill Bay B.C.
« Reply #10 on: September 22, 2018, 11:25:52 PM »
To go along with that routine I would spray some wd- 40 or parts cleaner aerosol into the vacuum port to flush out any specs of dirt or debris that could  plug the little hole in the attached pictures. When that tiny hole gets plugged up the petcock does not close when the engine is shut off.
Dusty
Daniel Meyer
« Reply #11 on: September 23, 2018, 05:30:28 AM »
Dusty
This is why in the "cover set" oem rebuild kit...they include that entire cover...that little hole/etc is a dampener...to reduce the intake backpulse from our rather aggressive cam timing...without it (and many aftermarket or "oem style" petcocks don't have it), the diaphragm will shred in  a matter of days.
CUAgain,
Daniel Meyer
dmerc
« Reply #12 on: September 23, 2018, 06:01:31 AM »
Should be easy to see if it's the fuel rail, with a small dental mirror and flashlight.  I did mine this spring, but did not remove the manifolds on the left side, only the ones for carbs # 3 and 5 (my leaker) Remove the support bolts tieing the banks together, then slid #5 carb over far enough to replace the o-rings..... $1.40 at NAPA, and a few hours of work. Saved a little time not pulling the entire bank of carbs. My #5 carb separated pretty easy (luckily) (watch those springs when separating)
