August 22, 2025, 01:40:40 AM *
Author Topic: petcock  (Read 1784 times)
Attic Rat
VRCC # 1962
Tulsa, OK
« on: September 22, 2018, 01:27:51 PM »
Has anyone besides me noticed that Honda changed the petcocks on the 2002 & 2003
Jruby38
Oxford Mass.
« Reply #1 on: September 22, 2018, 03:56:08 PM »
I hope they are better than the 99 POS.
sixlow
St. Augustine, Fl.
« Reply #2 on: September 22, 2018, 04:31:48 PM »
Do tell, how do they differ ?
Gideon
Indianapolis, IN.
« Reply #3 on: September 22, 2018, 05:21:35 PM »
I am all ears!
What was changed???
« Reply #4 on: September 22, 2018, 08:31:35 PM »
What was wrong with the '99's?  My '97 has 120+ on it with zero problems.
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
« Reply #5 on: September 22, 2018, 08:41:42 PM »
 A 97 with 120k and the original petcock one can only assume you are in an area that doesn't sell ethanol gas!  I had to replace mine on my 98' recently and it was in bad shape I was lucky not to have damaged the motor when it hydro-locked!
« Reply #6 on: September 22, 2018, 08:49:05 PM »
Nope rin ethanol all the time. Never touch the petcock.havent since day one. 21 yrs and no trouble.
« Last Edit: September 26, 2018, 03:48:21 PM by Bighead » Logged
JimBob
Diamondhead, MS airport (66Y)
Mississippi Gulf Coast- Hancock county
« Reply #7 on: September 23, 2018, 12:41:43 PM »
1999 p/n 16950-MBY-003, superceded to 16950-MBY-013, then -023, and now -033.
2003 p/n 16950-MZO-033
The illustration appears to be unchanged.
OK Rattie.... this 'newbie' will 'bite'......what changed?
Presently running:
'97 Valkyrie Tourer, '99 Valkyrie Interstate
'08 Buell 1125R, '06 Buell XB12X Ulysses, '06 Buell XB12S Lightning
'95 Suzuki GN125, '85 Suzuki GN250, '80 Suzuki TS125, '80 Suzuki TS250
Projects: '04 Buell Firebolt, '00 & '04 Buell Blasts, '74 Suz TM400, '78 Suz TS185
Blackduck
West Australia
« Reply #8 on: September 26, 2018, 05:38:54 AM »
Co-incidence , have just been looking for a cover set and there are 2 part numbers. The years listed are all over the place (Partzilla's parts lists have the years they suit). Bit of a mix and match.
Cheers Steve
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #9 on: September 26, 2018, 06:58:06 AM »
I ordered both petcocks so we will find out next week when they come in.
Blackduck
West Australia
« Reply #10 on: September 26, 2018, 03:28:19 PM »
Honda Line Direct parts lists have the superceded numbers, they all update to 16950-MZO-033 and cover set to 16953-MBZ-B51.
Differences? who knows. The question would be if the latest cover set will work with earlier petcocks
Cheers Steve
SPOFF
Derry, NH
« Reply #11 on: September 30, 2018, 05:12:08 AM »
I've read awful things about the OEM petcocks but I just rebuilt the petcock on my 1997 only because it was going on 22 years and hydrolock sucks. But the petcock didn't need it. It still worked normally. I guess the 97s really were better    smitten
indybobm
Franklin, Indiana VRCC # 5258
« Reply #12 on: September 30, 2018, 07:15:16 AM »
I think that over time Honda gets parts from different manufacturers and the different part number reflects that.
So many roads, so little time
VRCC # 5258
Blackduck
West Australia
« Reply #13 on: October 25, 2018, 04:29:02 AM »
AR,
Did you ever find out what if, any differences there are in the valves?
Cheers Steve
franco6
Houston, TX
« Reply #14 on: October 26, 2018, 06:43:20 AM »
I have often wondered on the petcock issue if the ones going bad belong to owners who constantly switch to the off position or and wait to turn on reserve before refueling?
the ball in the petcock travelling back and forth does damage the o ring.
two more cents Grin
Enjoy the ride!
« Reply #15 on: October 26, 2018, 06:59:20 AM »
On Deerslayer, my high mileage 98, I installed a Dan-Mark around '98 and never change it from the ON position unless I need reserve.  It has the OEM petcock.  So the vacuum shutoff and the solenoid both shut the fuel off and if the vacuum fails I don't care.  I have since changed the wiring of the Dan Marc so it is powered by a latch relay powered by the kill sw output that must be tripped on by a hidden push button or the fuel remains off.  So the fuel goes off if the ignition or the kill sw are off, or the bike is tipped over.  Wiring described at http://www.horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
