July 12, 2025, 05:13:00 PM *
Author Topic: just started sputtering  (Read 1225 times)
scarylarry
wis rapids, wi
« on: September 23, 2018, 01:26:15 AM »
  was riding pretty hard, up, around and down the bluffs today..ran like a champ..hit the highway to go home and all the sudden lost power{still running}..still idles..no pops..hard to explain the sound but I would say flat and vibrating.. basically doesn't want to take fuel..really hard to take off from a stop..will run at 65 mph ok but tops out at 75 full throttle..just from the finger test in the exhaust seems like all cylinders are firing..seems like it could be a hundred different things..btw,,no I have not worked on or changed anything lately..hoping 1 of you knowledgeable folks could help me get started in what to look for/ test..after thought.. I did open the gas cap thinking maybe vent hose..no change..any ideas are greatly appreciated
« Reply #1 on: September 23, 2018, 03:18:44 AM »
Fuel line filter? #4
https://www.ronayers.com/oemparts/a/hon/5054120ff870021c54bee67b/fuel-tank
Petcock diaphragm?
Someone brighter than me will have an answer.
« Reply #2 on: September 23, 2018, 04:26:31 AM »
Being that you ruled out a kinked vent line. I would suspect a failing petcock. A new cover set is probably in order.
3W-lonerider
Shippensburg Pa
« Reply #3 on: September 23, 2018, 04:39:58 AM »
Classic signs of a failing pet rooster.
h13man
Indiana NW Central Flatlands
« Reply #4 on: September 23, 2018, 04:53:03 AM »
Check the plugs. Mine would do this every 10,000 mi. Done it twice so I switched to Iridiums plugs. OEM says to change every 8,000. I ride until they quit and keep a spare on board. Old habit from dirt days.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: September 23, 2018, 05:13:26 AM »
could be that something from the road is blocking the air inlet on the airbox.
So many roads, so little time
VRCC # 5258
Jims99
Ormond Beach Fl.
« Reply #6 on: September 23, 2018, 05:17:28 AM »
I agree. Same has happened to me. Mine ended up being a small split in vacuum line. Couldn’t see it, but found spraying starting fluid around hoses.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Pete
« Reply #7 on: September 23, 2018, 05:29:05 AM »
If you suspect the petcock is beginning to fail, go to reserve to see if that clears up the issue or fill the tank.
If either resolves the issue, order the cover set and a vacuum line, replace both.
And clean the petcock very well inside with cleaner and compress air.
« Reply #8 on: September 23, 2018, 06:06:50 AM »
mine did the same thing.  Installed the cover set thing.  Did it again a year later.  Thats when I went to a Pingel.  Been ten years and no trouble whatsoever.  The problem is that the OEM when functioning perfectly can only supply exactly enough fuel for hard accelerations or operating at top speed.  Any reduction in fuel delivery capability is a rideability issue at max flow situations.  The Pingel easily flows as much as the engine demands under any conditions and has no diaphragm to tear.  Just keeps working and working.  its a quality piece of equipment
« Reply #9 on: September 23, 2018, 06:28:56 AM »
Wow, that’s odd. I’ve got a combined 190k on original plugs. I’ve had new ones waiting in the wings for about 3 years now. One day I’ll get around to switching them out.
Tfrank59
'98 Tourer
Western Washington
« Reply #10 on: September 23, 2018, 07:51:55 AM »
yeah it's strange mother Honda says 8k to replace spark plugs (had to check the manual Grin).  I have over 40k on mine, check them occasionally to see if tan, but not going to change NGKs every 8k unless there's a problem how they're firing--and if there is it's likely not the plugs!
-Tom
scarylarry
wis rapids, wi
« Reply #11 on: September 23, 2018, 09:43:58 AM »
To update, I touched the exhaust pipes again today and no. 1 cylinder is cold..Pulled that plug wire and started it up..runs the same..could 1 dead cylinder cause the problems I described above..I completely toppped off with fuel and switched to reserve..no change.  I just want to be sure the petcock is the problem before changing it.. Thanks for the help
Pete
« Reply #12 on: September 23, 2018, 09:53:17 AM »
Sometimes it can be a little difficult to feel one missing cylinder. Yes fix that first and retest.
scarylarry
wis rapids, wi
« Reply #13 on: September 23, 2018, 10:30:11 AM »
1 more observation..if I let the bike sit for 1/2 an hour or more it seems to run fine for a cpl mins..then the loss of power returns..would this help confirm a petcock problem?
« Reply #14 on: September 23, 2018, 12:07:35 PM »
Yes, absolutely, fuel trickles in then gets used up faster than the fuel valve can replace it.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #15 on: September 23, 2018, 06:16:49 PM »
Did you make ANY change to the fuel lines? i,e, Quick disconnect, filter, new hose???
Rio Wil
« Reply #16 on: September 23, 2018, 06:54:47 PM »
Ditto on the above, these engines are so easy on plugs, unless you have some issue that's fouling plugs, every 100K miles  changes are fine. Even at 100K, you won't likely see any performance change with new plugs......it's just one of those feel good things for doing something nice for the old gal.
scarylarry
wis rapids, wi
« Reply #17 on: September 23, 2018, 11:02:47 PM »
problem solved..turned out to be a loose wire on the #1 and 2 coil..crimped it a bit tighter and runs smooth again..Thanks for the help everyone
Forge
San Antonio, TX
« Reply #18 on: September 24, 2018, 03:33:55 AM »
Glad you got her sorted out!
Tfrank59
'98 Tourer
Western Washington
« Reply #19 on: September 24, 2018, 05:47:54 AM »
Yeah thanks for the update. That's got to be one of the first times someone's reported that problem
-Tom
h13man
« Reply #20 on: September 24, 2018, 07:02:40 AM »
As you've said many times before.  Wink To everything there are exceptions. Maybe this winter I'll get my ride completely gone thru as the parts keep piling up for the project!  Smiley Otherwise I'll keep riding until Nov. Hopefully the weather stays good. Remember I live in a climate that the air humidity/temps can go up and down like a yo-yo.
scarylarry
« Last Edit: September 24, 2018, 07:09:32 AM by h13man » Logged
