June 26, 2025, 05:14:22 PM *
Author Topic: ? Heated grips.  (Read 907 times)
gregk
Retired
Chippewa Falls, wi.
« on: September 24, 2018, 11:15:23 AM »
I have some snowmobile heated wires I put on the handle bars and need a little help connecting the wires to a toggle switch for Hi Low Off.   Wires are  Yellow,   blue,  green.
I'm guessing a hot wire to the center pole.
                      Green wire to a ground on bike.
                     Yellow wire for a hi or low.
                         Blue wire for the other hi or low.
WintrSol
Florissant, MO
« Reply #1 on: September 24, 2018, 11:29:02 AM »
I think you want a center-off, SPDT switch (ON-OFF-ON); you may want to search for an electronics hobbyist shop in your area. Next problem is mounting it. You may also find a rotary switch with a knob that has similar settings. Without the OFF option, they will always be on, which you don't need in hot weather, There are other switch that can provide the same three-state controls, but are harder to describe on a forum. Also, you may need the current rating of the highest power setting - got a data sheet?
gregk
Retired
Chippewa Falls, wi.
« Reply #2 on: September 24, 2018, 12:01:55 PM »
I have the SPDT Sw. mounted.  I think I have it right but looking for conformation.
With a hot to the center pole. An green to ground if I have the color right,  and say Sw. thrown to that green , the current should flow through the wires to the green ground wire.  I assume the wires in the heater are nothing more than a rheostat providing a set amount of heat.
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
« Reply #3 on: September 24, 2018, 01:52:16 PM »
Assuming you are correct with the colors then it sounds correct.  One question is the switch rates for the amps that the heater draws and where did you pull power from if you connected to the battery then make sure you have a fuse with the correct rating as well.
gregk
Retired
Chippewa Falls, wi.
« Reply #4 on: September 24, 2018, 06:05:03 PM »
Thanks, 15A fuse. Relay, heater sw., lighted guage for air comp.  ( with momentary sw. ) to shocks, lighter only used for emg. phone charger. All this not used at same time. I believe heater grips will only be used on low.
« Last Edit: September 24, 2018, 06:06:41 PM by gregk » Logged
« Reply #5 on: September 25, 2018, 06:46:18 AM »
I have the switch on my IS, SPDT (on-off-on), mounted in the inner fairing, but it includes a light so I know it's on, and is wired into the accessory, so powers off/on with the ignition. VERY important if you expect to be able to restart your bike again.
gregk
Retired
Chippewa Falls, wi.
« Reply #6 on: September 26, 2018, 08:06:57 AM »
Gordon , yup I forgot to say power to the relay goes through a lighted rocker SW. (Boat type) mounted on the handlebar that stays in the off position and in the other forward position it operates a relay for the fog lights.
 Gordon, sorry I mispelled your name.corrected.
« Last Edit: September 27, 2018, 06:43:18 AM by gregk » Logged
