March 30, 2026, 04:38:57 AM *
Author Topic: SMOKIN!!!  (Read 1320 times)
« on: September 26, 2018, 04:45:09 PM »
ALRIGHTY BRUCE.
I said I'm workin on my new BBQ project,
BRISKET!
Now to start with, I don't have the right smoker.  Got two Brinkmann charcoal smokers, but brisket has to be smoked A LONG TIME - Typically a dozen hours / overnight.  LOW AND SLOW - typically 225° with the wet method.  Or so they say, if you read up on it.  Chardcore (Franktown BBQ place) hired a kid to work their smoker all night - and all the work I think is the reason they rarely have it.  HotGlue does the same for the GOTF - hires kids to work the smokers all night.
OK I'm not doing that.  So I need an automatic pellet feed smoker.  Also these smokers are pretty good at keeping the temp steady - at least according to the Brinkmann analog thermometer I stuck in the top - the temp reported by the smoker is all over the place but that's OK as long as the temp near the meat is pretty steady.
This one holds 60lbs of pellets in a hopper on the back.  Will smoke at least 24 hrs w/o fueling. However it needs the water replenished at least every 3 hours.  I found this Pit Boss CopperHead locally under $400.  Big box stores have it - Costco, Walmart, Lowes, Menards, Ace Hardware, Home Depot and others are all listed as sources at https://pitboss-grills.com/Shop-Pit-Boss/Grills/vertical-smokers/5-series-vertical-smoker-wood-pellet
I'm a big fan of Mesquite smoke for baby back ribs and smoked salmon.  However it's too strong a flavor for brisket.  Especially if you're going to smoke it LOW and SLOW.  I used hickory here. Besides - it's easy to find hickory pellets.  You will probably have to get mesquite online and that's much more costly.  I get 20# of hickory locally for $8.88. The going rate online for 20# of mesquite pellets (and other flavors including hickory) is around $25. This smoker uses about a half a bag of pellets 10# in 9 hours of smoking at 225°.  I buy mesquite wood at Denver Firewood for smoking for cheap - but they aren't pellets.  That's for manual charcoal smokers.
This baby can make some SERIOUS SMOKE!
OK, we are on SMOKIN TEST NUMBER TWO.  The first test, we followed the rules on a 5# brisket I got at Safeway.  Came out kinda tough and dry.  Yep we salvaged it, but it's clear the process needs a tweak or 2.
Smoked it too long.  Didn't mop it. A couple other things.
This is SMOKIN TEST NUMBER ONE.
For TEST NUMBER TWO I adjusted the temp control up 25° as the analog thermometer inserted in the top indicated too cool.  The temp reported by the Pit Boss was all over the place, generally too hot. But that probe is close to the fire so it's bogus.  I lowered the finish temp in the smoker - instead of taking it all the way to 190°, I took it to 152° and pulled it.  The Pit Boss has a temp probe for inside the meat. Supports 2 (2 ports on the control panel) so the 2nd one is available at their site.
Turns out, smokin a great brisket, a lot of the quality comes from picking the right brisket.
I bought a much bigger brisket at Costco - biggest they had was 14# but it was a full brisket with the point and the flat, and with a thick cap of fat.  Even better, it's grade was PRIME!  YAHOO, heavily marbled!!!!
I separated the point from the flat, and this time cooked only the point and froze the flat.  Both times the meat was heavily rubbed. I made 2 qts of mopping juice, and mopped it every 30 minutes starting at 4 hrs.  The time it took to get to 152° was the same as the flat before took to get to 190°, but this brisket point is 9#.
Pulled it from the smoker at that temp, took it into the kitchen and thoroughly wrapped it in foil, after a good mopping.  After it's smoked, the brisket can be finished in an oven, and wrapping it makes it steam. Continued for 3 hours in the oven at 225°.  At midnight I turned down the temp to 200°.  Got up at 3AM and checked the temp - 192.6°.  PERFECT!  Pulled it from the oven and let it rest until dawn.  Total hot time was 16 hours, with 9 in the smoker at 225°, 3 wrapped in the oven at 225°, and 3 at 200°.  When I removed it at dawn the meat was totally squishy - tender.  When I shoved the temp probe in it at 3AM it was like pushing a toothpick into a cake!
There are a ton of rub and baste recipes, and every brisket cook has his opinions on the perfect method.  I am concluding a lot of those method variances don't matter much, as long as you follow some basic rules.  Low & slow, smoking for a shorter time - say half the time is OK - once it's smoked it can be finished in an oven also low and slow, and wrapping it well in foil for around half the time will seriously tenderize it.  You can have fun with a lot of different seasoning recipes, and every one of them will be DELICIOUS!.
OK so here's some pics of BRISKET TEST NUMBER TWO:
This was cut after it had been chilled in the fridge.  Check the marbling!  When I unwrapped the foil, there was a ton of juice captured there.  I poured it into the bowl.  Now that juice is great for re-juicing the brisket!  I vacuum-wrapped 2/3 of the meat in serving portions for 2, and froze it.  (Foodsaver)  Put 3 more dinner's worth in the bowl with the juice and fridged it.  When we're done with that in a week or so I'll put the remaining juice in portion containers and freeze it too.
JUICIN THE BRISKET:  Put a serving in a bowl. Pour some juice on it.  Cover the bowl and nuke it for 2 minutes.  The juice can be returned to the storage bowl with the rest since it won't have your mouth on it.
SWEET BABY RAY'S:  The best store-bought BBQ sauce there is IMHO and I've tested dozens.  Of course if you have a home-brew (and I do) it just might be better but I ain't giving my recipe away!
Put the hot juicy slices on some buttered great craft sourdough bread, add some SBR and Habanero Tabasco, and you will think you're in Brisket Heaven!
« Last Edit: September 27, 2018, 11:12:24 AM by MarkT » Logged
« Reply #1 on: September 26, 2018, 05:04:14 PM »
I love pie, and brisket
Sure miss GOTF
thanks for making me hungry mark
« Reply #2 on: September 26, 2018, 05:05:38 PM »
And I just had a salad for supper Undecided
« Reply #3 on: September 26, 2018, 05:09:26 PM »
Made me laugh. Thanks.
« Reply #4 on: September 26, 2018, 05:09:52 PM »
2funny
« Reply #5 on: September 26, 2018, 05:20:25 PM »
I had a decent brisket sandwich in Cashiers NC on Monday...
« Reply #6 on: September 26, 2018, 06:10:56 PM »
looks yummy.
agree,  for the price paid hard to beat sweet baby rays..  cooldude
Shasta
« Reply #7 on: September 26, 2018, 07:21:18 PM »
Looks good.  Try less smoke too.  Should just be a thin blue ribbon of smoke not billowing white smoke.
« Reply #8 on: September 26, 2018, 07:41:12 PM »
Stubbs make a great BBQ sauce.
« Reply #9 on: September 26, 2018, 08:23:48 PM »
Nice hobby Mark.   cooldude
I must say, this put me in mind of some of the more exotic giant bongs I saw in college.  Grin
« Reply #10 on: September 26, 2018, 10:11:30 PM »
It's not smoking meat in that pic which is deliberately misleading. It does that while starting up.  Not very smoky most of the time.  It smokes when the computer calls for heat, when the "actual" temp drops below the set temp and the auger feeds in more pellets which provide the heat and smoke. More pellets in the firebox, ignite & smoke and temp rises and auger stops.  The top pic above is while smoking meat & you can see the meat through the glass all the time. Not in the startup / warmup pic.
« Last Edit: September 26, 2018, 10:17:22 PM by MarkT » Logged
bg
Cumming, Ga
« Reply #11 on: September 27, 2018, 02:14:44 AM »
did my first brisket yesterday.......everyone said it was gooooooood.......cooked it on my old Brinkmann Electric.
just bought that same smoker you have and can't wait to try it out........wanted something bigger and able to control temp....
G-Man
White Plains, NY
« Reply #12 on: September 27, 2018, 04:35:16 AM »
I have the Bradley that feeds sawdust disks in many different flavors.  The spent disks fall into a bowl of water that is also there to provide humidity.  Has 6 racks so you can smoke a lot of meat, but........  the temperature is very difficult to control.  It's electric so it heats up slow, then loses all the heat when you open the door to load the meat.  Then it takes a long time to come back up to temp.  Remember, we're talking around 250 degrees and it takes a long time to reach temp and then loses it all when you load or tend to the meat.
« Reply #13 on: September 27, 2018, 06:50:03 AM »
The Pit Boss Copperhead (and I'd bet the other vertical models) heat up pretty quick after being opened.  You do need to install another thermometer in it.  I just drilled the right size hole in the top and stuck the Brinkmann one in there. I've found setting the temp control at 250° puts the Brinkmann therm at 225°.  Stays there pretty well until you open it when it drops to 185 or so when you mop the meat.  Close it and it's back up to 225 in around 5 minutes.  Meanwhile the "actual" temp reading on the smoker control panel is at least 50° higher.  And the smoke is pouring out.
The pellets burn up completely with virtually no ash in the burn pot. It appears they turn into a fine powdery ash which is blown out of the pot by the fan and a small amount of powder remains on the bottom of the smoker.  I thought there would be more - even after 9 hours, not much.
The Copperhead has 5 ceramic coated racks - I remove all that are not needed while smoking to keep them clean.  Leave in one to hold the meat and one for the mopping pan to catch the juice under the meat.
« Last Edit: September 27, 2018, 08:01:01 AM by MarkT » Logged
Atl-Jerry
Alpharetta Ga
« Reply #14 on: September 27, 2018, 11:37:18 AM »
I like the Sweet Baby Ray's but it's a little too sweet for my taste.  I usually mix it half and half with Kraft original.  When time permits I like to carmelize finely diced Vidalia onions and simmer with the sauce  in the pan.  And if you get one of those sheet metal oil change pans from Wally World and place it under the smoker you can keep the spills, drips and stains off the floor.
henry 008
BRP
willard, oh
« Reply #15 on: September 27, 2018, 11:48:08 AM »
I really like winking lizard bbq sauce, better than most you can get at the grocery store.
https://winkinglizard.worldsecuresystems.com/online-store#!%2Fglassware-bobble-heads-and-more%2Fbbq-sauce-6-pack-original%2F
Safe Winds... Brother
Pete
« Reply #16 on: September 27, 2018, 02:27:13 PM »
Smoking meat more than 3 to 4 hours, may be enough.
I use charcoal and hickory wood after 3 to 4 hours I have excellent smoke penetration.
So I wrap and add moisture and put in an oven for 6 to 8 hours at 225.
This procedure works for beef and pork, for turkey and chicken they may be done when smoked or shorten the oven time.
« Last Edit: September 29, 2018, 06:58:56 AM by Pete » Logged
« Reply #17 on: September 29, 2018, 04:42:31 AM »
Mark,
You sound like some sort of garage chemist or patio scientist bent on finding a revolutionary new way to develop and/or fine-tune old recipes! Whatever, your 'product' looks downright magnificent!!! I'm really partial to BBQ, being a southern boy through and through, so anything attempted along this line would naturally interest me...   Cool
I'd love to sample your wares! Maybe next time I'm out your way, I could persuade you to pull a pack of that out of your freezer and make a sammich out of it for me!!! If it tastes anywhere near what it looks like, I'll bet it would make me wanna slap my mama!  cooldude
P.S. After posting this, I thought more about it and decided to add another observation... As gratifying as a fine meal is, that is actually only a small part of the larger picture. You, like Hotglue, thoroughly enjoy the figuring out of such an undertaking, stitching together in proper sequence all of the various parts, aspects, details, and ideas, then 'doing' all that goes into producing a satisfactory, and satisfying, outcome. Like with most of the 'best things in life', it truly is about the journey and not just the destination... Congratulations! I salute you, sir, and I tip my hat (helmet) to ya!!! Well done...
« Last Edit: September 29, 2018, 04:58:35 AM by DDT » Logged
« Reply #18 on: September 29, 2018, 04:57:23 AM »
I have been examined and I’m missing the “cook” gene. Sad
