November 14, 2025, 09:13:33 AM *
Author Topic: Bent frame?  (Read 1336 times)
Jims99
Ormond Beach Fl.
« on: September 27, 2018, 04:22:09 AM »
I’m going to look at a Valk that’s been wrecked, front end only. I know forks are bent, front tire almost touches front of engine. Is there a way to tell if frames bent by looking. I know to look for stress or cracked welds, but anything else? Not sure how bad it is till I go look. Picture he sent aren’t that good. Thanks.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
« Reply #1 on: September 27, 2018, 04:35:46 AM »
Take off the engine guards and then put them back
on... they always take a little fiddling, but if you have to
resort to a come-along to get stuff to line up there
might be something tweaked...
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #2 on: September 27, 2018, 05:41:16 AM »
Usually what bends is the lower frame rails. They just bolt on easy fix just replace them
gregk
Retired
Chippewa Falls, wi.
« Reply #3 on: September 27, 2018, 06:55:02 AM »
I will tell you do not do it. You can buy a new frame with out #s if you need one.  10 to 1 I bet the frame is bent  on the top rail behind the neck and you cannot bend it to straighten it out. You will not be able to tell unless you take the tank off.
« Reply #4 on: September 27, 2018, 10:03:29 AM »
look for cracked and/or wrinkled paint.
Bagger John - #3785
« Reply #5 on: September 27, 2018, 10:44:49 AM »
This right here, especially around the neck and associated weldments.
sixlow
St. Augustine, Fl.
« Reply #6 on: September 27, 2018, 01:55:38 PM »
Jim, is this the bike in Bunnell ? I went to look at it also, problem is he has 3 or 4 bikes in the way of getting to it. Make him move it out to get a better look. I saw the tank has been hit by the forks at the fold in the tank edge on the right side, that kinda scared me off as I can't see how that happened without some serious impact. Rotors are bent but wheel looks o.k. but without rolling it is hard to say. I offered 1k but he wouldn't go any lower than 1500 at the time, 6 weeks ago. Go take a look and good luck.
« Reply #7 on: September 27, 2018, 03:59:39 PM »
I had bent the forks in my front collision, tire touching the engine. Thought the frame was fine, till after sitting outside without the gas tank on it. Then all those non-visible paint cracks started to have rust bleed out of them. Like mentioned, the flat plat at the front and rear of the tank had ripples in it.
I bought mine back from the insurance company for $1K. At that time, you couldn't buy a frame without a title. Now I see them for less than $500 everywhere. But straight forks are very expensive. Price out the parts BEFORE you buy a wrecked bike, unless you are buying it for the parts.
SPOFF
Derry, NH
« Reply #8 on: September 27, 2018, 04:06:05 PM »
One type of damage that can be difficult to spot is when the steering stem is not round but bent into a slightly oval shape. This is very common with wrecked sport bikes.
Jims99
Ormond Beach Fl.
« Reply #9 on: September 27, 2018, 07:40:59 PM »
Thanks all. Good advice about removing and looking under tank.
yes, that’s the one. Thanks for heads up, I’ll see what I can do price wise. Definitely get him to move stuff away. Let you know after I see it.
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
Flrider
Jack
Kissimmee FL
« Reply #10 on: September 30, 2018, 07:48:28 PM »
Jim
Jack from Kissimmee here
Hope it works out for you and don't forget to check inside the tank for rust.
If you need a frame, I have one with a good Florida title
Jims99
Ormond Beach Fl.
« Reply #11 on: October 01, 2018, 04:22:34 AM »
thanks jack. I’m trying to get out this week to look. Let you know Saturday.
Jim
99 tourer
00 interstate
97 standard
91 wing
78 trail 70
