December 20, 2025, 01:31:03 AM *
Author Topic: Communial Valkyrie parts to share.  (Read 5854 times)
« on: October 03, 2018, 05:02:03 PM »
MSB suggested, so I'll start.
I suggest you post what parts you have that you are willing to share, and maintain the list yourself. Just edit your original post to update it, as things change.
Add a way to contact, if other than through the forum.
PLEASE DO NOT POST HERE ASKING SOMEONE FOR SOMETHING THEY HAVE, contact them directly. There is no guarantee when the post would be read by the person it is intended for.
You can post for WANTED items.
« Last Edit: January 17, 2021, 09:38:10 AM by gordonv » Logged
« Reply #1 on: October 03, 2018, 05:22:19 PM »
Items I have, from memory. It's also nice listing what I have.
digi-sync - for loan
handle bar levers
reservoir covers - new
air filter - new
petcock - needs rebuilding
GW petcock - vacuum without a shut off
starter
alternator
u-joint - new from a GW
u-joint
carburetor set
IS kick stand switch
Shadow ignition switch (same as an IS)
OEM head lights & H4s
bulk balance beads 0.8 mm
Std/T brake light and wire harness - msb is grabbing it from me (interferes with the CB mounted under the trunk)
I have these, but am intending on using them myself.
exhaust gasket
alt brushes
Pods with fog light holes
fog lights (missing rubber)
GW neutral switch
Shadow manual petcock and electric fuel pump
but if you are in need, they can be given pending replacement.
I have parts I took off my IS. Some I've replaced, and the used damaged piece is still around. I can think of the front turn signals.
I did remove the one piece trailer hitch
BonS Smartswitch direct headlight wire, did not work with my head light modulator, so will be selling it along with other parts, after I figure out what I have.
I've still gotten a mounted ATT on a rear rim, waiting to replace my MC rear wheel
« Last Edit: August 01, 2021, 04:51:44 PM by gordonv » Logged
msb
Agassiz, BC Canada
« Reply #2 on: July 31, 2021, 06:06:08 PM »
I currently have the following parts that I am willing to lend out to a fellow Valk rider in need to get on the road if replacement  parts otherwise aren't immediately available... whether they live in BC, or are just passing through and  require an emergency replacement.
U joint and Boot...used but in very good working condition
Drive Shaft and matching Pinion Cup...used but in very good condition
Final Drive Unit...useable, approx 30-40% wear on splines, other internals good
Rear Wheel Flange...new
Yuasa Battery...3 years old, holds a good charge, starts bike easily, kept on a tender
Complete Interstate Exhaust System ...used, some corrosion on bottom of headers but otherwise in good shape and unmolested
Interstate Shocks...used, condition unknown
Water Pump...used, replaced gasket
OEM Clutch, Brake Fluid Reservoir Covers...used
OEM Passenger Foot Pegs...used, very good condition
Rad Screens...1 OEM, 1 Chrome
Interstate Rear Rotor...used, just under 5.5 mm but straight.
Interstate Horn...used, works
Interstate Radio Antenna and Mount...used, good shape
Front and Rear Wheel Bearings...new
OEM Shock Bushings...new
Intake O-Ring Set...new
Dunlop E4 Rear Tire...sized for 1800 Wing (1/2" shorter, same width) but works on Valk...great shape, about 30% wear
OEM Dip Stick...used
OEM Rad Cap...new
Oil Pan Crush Washers...new
OEM Interstae Seat...1 year old, perfect shape
Front and Rear Signal Light Lenses,  2 Hole...used, orange and smoke
OEM Oil Filter...new
2 Alternators...1 OEM and 1 lightly used aftermarket. Latter has been used and works perfectly, former hasn't been used, but acquired as "working"
2 Sets Rear Wheel Dampeners...used, both useable
OEM Clutch and Brake Levers...used, but perfect shape
Misc Valkyrie Washers, Seals, Spacers, Nuts & Bolts, etc.
Homemade Fuse Panel
Interstate Smart Switch...new, unopened (will sell)
Garage Space, Lift & Adapter, Tools, Willingness to Help to the best of my Capabilities...and hot coffee or cold beer, for Emergency Work if Needed
Access to Trailer for Emergency Pickup if needed if riding in my neck of the woods
Probably have some other stuff I'm forgetting, but I'll add to this list if I come across it.  PM me here to contact , or message me on Messanger or through VRCC FB page (Mike Boldt)
« Last Edit: August 01, 2021, 08:32:59 PM by msb » Logged
'99 Red  & Black IS
