November 14, 2025, 09:23:23 AM
Those stupid bulbs
Topic: Those stupid bulbs (Read 1075 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
Those stupid bulbs
October 12, 2018, 12:18:24 PM »
What do we use to take out the ones in the Headlight bucket
Re: Those stupid bulbs
October 12, 2018, 01:16:39 PM »
Huh?
October 12, 2018, 01:23:04 PM »
If you mean the three indicator bulbs the Honda manual describes how to remove them.
Looks like you pry the lens from the case from inside the bucket ( small blade screwdriver?)
Last Edit: October 12, 2018, 01:32:57 PM by Chrisj CMA
_Sheffjs_
Sarasota FL
October 12, 2018, 01:34:45 PM »
Yes the lens off is easy now what? Get it out of the stupid boot is what I need
October 12, 2018, 02:07:31 PM »
Quote from: _Sheffjs_ on October 12, 2018, 01:34:45 PM
It says "pull out bulb socket". I assume that the boot
Jruby38
Oxford Mass.
October 12, 2018, 02:34:11 PM »
I just did it. Use needle nose pliers.
_Sheffjs_
Sarasota FL
Reply #6 on:
October 12, 2018, 03:53:28 PM »
Quote from: Jruby38 on October 12, 2018, 02:34:11 PM
That is what I have always used. Just hoped for a better way. No matter the bulbs are fine and so is the connector. Looks like I have another issue.
Reply #7 on:
October 12, 2018, 06:16:30 PM »
Jerry, a good dose of regular rubbing alcohol helps things such as glass bulbs sliding across rubber. That and needle nose.
=> InZane XXV
