September 18, 2025, 06:53:00 PM
Link to a desmog it thread?
Topic: Link to a desmog it thread? (Read 1214 times)
mello dude
Dayton Ohio
November 03, 2018, 06:03:46 PM »
Hi,
My bike is apart and now is as good a time as any to do the desmog it.
Can anybody point me to a link/thread for that?
Thanks!
Re: Link to a desmog it thread?
November 03, 2018, 06:14:07 PM »
http://www.valkyrieriders.com/shoptalk/desmog.htm
I did it as above, I filled the little chrome tops with jb-weld instead of
using freeze plugs.
There's a Red Eye desmog kit, I like it, especially those plugs...
https://redeye.ecrater.com/p/8464393/shiny-desmog-kit-ver-2-honda
1NorthRyder
Elliot Lake, Ontario, Canada
November 04, 2018, 03:30:38 AM »
I used the Red Eye Desmond kit. It worked very well.
mello dude
Dayton Ohio
November 04, 2018, 01:07:48 PM »
Thanks all for the tip -- I purchased the Redeye kit.
CleoBen
2000 Interstate
Lewisburg. Ohio
November 04, 2018, 05:34:45 PM »
Quote from: 1NorthRyder on November 04, 2018, 03:30:38 AM
I used the Red Eye Desmog kit. It worked very well.
Me too.
CB
Forge
San Antonio, TX
November 05, 2018, 04:42:34 AM »
I also did the Redeye kit as well as removed the carb drain tubes. It really cleaned up the engine. If I need to drain them, I do them one at a time with a length of hose and a coffee can.
mello dude
Dayton Ohio
Reply #6 on:
November 07, 2018, 09:11:21 PM »
Received the pair kit today. It's definitely a first class setup. Gotta read the directions a few times to get what's going on.
Reply #7 on:
November 08, 2018, 04:57:01 PM »
Quote from: Forge on November 05, 2018, 04:42:34 AM
+1 on the carb drain hoses
lakehunter
Chapin, SC USA
Reply #8 on:
November 11, 2018, 02:36:00 AM »
+1 on the shiny desmog kit, turned out wonderful. You might also consider the quick disconnect fuel tank kit with inline filter from the same folks. The inline filter saved me from a nasty carb disassembly and clean out when the diaphragm in the petcock failed soon after the desmog install. Bit the bullet and went to a pingel petcock, took about 5 rides to get used to where the shut off lever was but no problem now and the peace of mind is worth the extra reach needed. Wish I had done the pingel while the tank was off the first time. Good luck with your project !
=> InZane XXV
