January 01, 2026, 01:45:06 AM *
Author Topic: 2,4,6 bank cooler than 1,3,5  (Read 1441 times)
Fireman973
Graham, Texas
« on: November 14, 2018, 01:00:42 PM »
Upon start up with full choke the 1,3,5 exhaust is warmer than clutch bank exhaust.... after the engine warms up all seems normal any ideas ?
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #1 on: November 14, 2018, 03:26:25 PM »
Are all the enrichment valves on carbs 246 connected to the choke cable?
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Fireman973
Graham, Texas
« Reply #2 on: November 14, 2018, 03:29:16 PM »
Michael
Sounds like a good place to start
« Reply #3 on: November 14, 2018, 04:49:33 PM »
Michael
and adjusted equally to the left side
Fireman973
Graham, Texas
« Reply #4 on: November 15, 2018, 03:47:14 AM »
Michael
Copy that.....now if the weather will cooperate...I sure miss a garage... carports and lean to sheds don't really cut it.
pancho
Bonanza Arkansas
« Reply #5 on: November 15, 2018, 03:57:13 AM »
Hey Fireman, if you are taking these temp readings at idle speeds, I'd suggest to try opening the pilot jets (if you do not discover a problem with the enrichment valves) on the cool side until you have all cylinder headers coming up to temperature equally. If that does the trick for you, you will notice substantially better performance and power at the bottom end.
I just saw that you stated this happens with FULL CHOKE, so my suggestion probably will not apply.
« Last Edit: November 15, 2018, 04:04:48 AM by pancho » Logged
Rusty Pipes
« Reply #6 on: November 15, 2018, 06:36:21 AM »
I have read that those temp sensors don't work well on chrome. I use water in a squirt bottle.
WintrSol
Florissant, MO
« Reply #7 on: November 15, 2018, 07:33:39 AM »
They aren't accurate for a variety of materials, but polished chrome is one of the worst, with an emissivity of 0.058. Compare that to the rubber of your coolant hoses, at 0.86.
pancho
Bonanza Arkansas
« Reply #8 on: November 15, 2018, 10:19:40 AM »
When doing the procedure, you really don't need an accurate temperature, just the relative temperature difference between the headers, so you can get away with using an infrared thermometer,,  but it helps if your headers are black.
Valkyrie0002
Fredericksburg, Va
« Reply #9 on: November 16, 2018, 07:57:43 AM »
Those laser thermometers sample the average temperature in the circular field of view which varies by the distance you hold it from the surface.  You are not reading the temperature at the red dot unless you hold it very close.
You can put a piece of tape or paint a spot on the header to get the actual temperature on that spot.
Been riding since about 1985.  1st bike was a CB900F then 88 CBR1000 , 1990 VFR750F and 94 CBR1000F.  I bought my 2000 Std. Valkyrie new in 01.  Was an MSF Rider Coach for 12 years.  New owner of a 2014 Valk, Red, Non ABS.
Fireman973
Graham, Texas
« Reply #10 on: November 16, 2018, 12:51:52 PM »
Just to clarify I'm using the fanciest of temperature gauges , the palm of my hand, and using it at the exhaust and believe me there is definitely a difference.
pancho
Bonanza Arkansas
« Reply #11 on: November 17, 2018, 03:41:56 AM »
YEOWL....   Well, you are the fireman. Did you get a chance to look at the enrichment valve linkage?
« Last Edit: November 17, 2018, 03:50:04 AM by pancho » Logged
Fireman973
Graham, Texas
« Reply #12 on: November 19, 2018, 07:19:49 AM »
LOL haven't yet but I have to go back to the station for training on our new to us ladder truck. If I get to ride I'm gonna take a shot of the bike with our thermal imaging camera it will give a temp as well as verify my palm sensitivity.  Roll Eyes
pancho
Bonanza Arkansas
« Reply #13 on: November 19, 2018, 10:14:29 AM »
Here is a diagram of the pieces of the choke assembly components at the carbs. The choke cable pulls on the part labeled 20 on bank 2 4 6  which pulls the enrichment valves open, then the cable numbered 22 pulls on part 20 on bank 1 3 5 which opens the enrichment valves on that side.  These parts can be accessed by removing covers numbered 26 and 27.
Good luck tracking down the problem, and have fun on that new ladder truck.
https://www.partzilla.com/catalog/honda/motorcycle/1997/gl1500ct-ac-valkyrie-tourer/carburetor-assy
Fireman973
Graham, Texas
« Reply #14 on: November 20, 2018, 04:56:28 AM »
Thanks Pancho
So after a thirty minute ride prior to the station and making sure the enrichment valves were engaging properly I shot the TIC at the muffler ends and found a temperature difference of 10 degrees...I don't think that's enough to fret about and I'm gonna let that sleeping dog lay. Thanks again everyone for your help and replies.
