December 15, 2025, 12:06:35 PM
1800 Tech Board
Out of order !!
Topic: Out of order !! (Read 3190 times)
ledany
Paris, FRANCE
Out of order !!
November 16, 2018, 12:48:59 PM »
I changed my front brake pads today. I squeezed the lever in order to have the brakes back in place, and as the motor was running, I began to start a very very little burn in order to have the front brakes at their best. But the engine stopped all of a sudden and I can't start it again.
When I turn the key on, everything is normal except that I don't hear any bzzzz from the fuel pomp. I may try as many times as I wish to start the bike but obviously the fuel don't get where it should.
I hope that the fuel pump is not broken, and that there's a process I don't know to have the pump back.
Any idea ?
Thanks !
ledany
Paris, FRANCE
Re: Out of order !!
November 16, 2018, 03:58:41 PM »
Thinking about today's fuel pump breakdown, I'll have to check the fuse (don't know where it is !)
ledany
Paris, FRANCE
Re: Out of order !!
November 17, 2018, 07:05:16 AM »
I changed the fuse (under the seat) and everything is fine now.
I learned on the french board that it is not necessary to buy the OEM fuel pump if needed because you can find this one for example
https://www.ebay.fr/itm/181903564650
which costs nearly a tenth of the OEM one (900 $)
st2sam
N.E. Pennsylvania
Re: Out of order !!
November 17, 2018, 01:02:06 PM »
Glad you got it all straighten out Ledany.
Thanks for the fuel pump information.
use2b
Perdido Key Florida
Re: Out of order !!
November 18, 2018, 05:12:27 AM »
glad it was that simple. my bike had a frozen fuel pump from sitting in the crate 4 years and the tank had to come off. I have no idea how they fixed it , WD40 and a hammer bump i guess ..............
The best part about growing up in Florida is i didn't have to move here when i got old.
2014 Valkyrie GL1800C and 2013 CB1100AD K10
bscrive
Ottawa, Ontario
Re: Out of order !!
November 18, 2018, 08:12:53 AM »
Really great info on the fuel pump if I ever need one. Thanks Ledany.
Glad you got your problem fixed.
ledany
Paris, FRANCE
Re: Out of order !!
Reply #6 on:
November 19, 2018, 01:31:06 PM »
In fact, it was not a big deal at all. I was just surprised that the sooo reliable Valk could fail suddenly. I read in a US board that the problems with the fuel pump (OEM or not) mostly come from elsewhere, so I think that most of us won't ever have to change the fuel pump.
=> InZane XXV
