Ron Baker
« on: November 16, 2018, 05:11:11 PM » |
This could verge on being a dumb question, but do you mount the lift adapter permanently under your scoot or just put it under there when you want to lift the bike? Thanks, Ron
1999 Red/Black Interstate
NewValker
VRCC# 36356
Oxford, MA
« Reply #1 on: November 16, 2018, 05:26:41 PM » |
Mark T sells the best one, bolt on, forget it till you need it. Craig
Turns out not what or where, but who you ride with really matters
« Reply #2 on: November 16, 2018, 06:04:51 PM » |
What Craig said. There are others that are designed to be temporary, some have accidentally left them on. So be careful if you get one of those.
« Reply #3 on: November 16, 2018, 06:46:34 PM » |
I made my own. Its designed to come off after use. Never considered one that was permanent.
« Reply #4 on: November 16, 2018, 08:24:12 PM » |
Mark T's adapter is a very good design.
Using a lift adapter makes lifting the bike much easier.
RDKLL
VRCC #1231 VRCCDS #271
Mesa, AZ
« Reply #5 on: November 17, 2018, 03:29:16 AM » |
I have the Mark T and highly recommend it. I have had the other style of permanent. Mark's is far superior and a more stable lift.
Ron Baker
« Reply #6 on: November 17, 2018, 04:22:47 AM » |
I should have added that I have one like Ross Spoonland's. I take it that it is made to be temporary?
Ken aka Oil Burner
« Reply #7 on: November 17, 2018, 05:51:54 AM » |
I bought mine from Mark T. and definitely recommend it. It is meant to be installed and left there. It doesn't interfere with any normal servicing, and the weight is a very minor addition to our heavy bikes. What little weight it adds is down low, too. The reason I would go with the "permanent" addition has nothing to do with servicing your own bike at home. What if you're out somewhere and have a tire go down (assuming it's a cut or some other non-pluggable damage)? If the shop isn't a Honda dealer, they may not have a good way to lift your bike except by the bottom of the cases. While the lift adapters do attach to the bottom of the powertrain, they spread the load out and give you a flat surface to lift from.
« Reply #9 on: November 17, 2018, 08:49:08 AM » |
Yes.
Alberta Patriot
« Reply #10 on: November 17, 2018, 12:32:48 PM » |
This one came with the bike but was not installed. It took about 10 minutes...just secured to the crossmember at OEM bolt locations.
Ron Baker
« Reply #11 on: November 17, 2018, 04:29:44 PM » |
Ok, I'm convinced, where do I find one of Mark T's.
NewValker
VRCC# 36356
Oxford, MA
« Reply #12 on: November 17, 2018, 07:39:32 PM » |
See top of page Horseapple.com
Craig
« Reply #13 on: November 17, 2018, 08:34:18 PM » |
Ron, It's not listed on my site. But my contact info is, on the footer every page at www.horseapple.com call me or drop an email, the adapters are $67 + $15 for priority mail. Make them in models for use with belly tank or non-belly tank. In stock, shipped with next mail pickup, accept paypal through valkstuff@horseapple.com, also credit cards - call them in. Thx. For belly tank bikes:  For no belly tank:
« Last Edit: November 17, 2018, 08:38:51 PM by MarkT »
Ron Baker
« Reply #14 on: November 18, 2018, 12:06:47 PM » |
Ron, It's not listed on my site. But my contact info is, on the footer every page at www.horseapple.com call me or drop an email, the adapters are $67 + $15 for priority mail. Make them in models for use with belly tank or non-belly tank. In stock, shipped with next mail pickup, accept paypal through valkstuff@horseapple.com, also credit cards - call them in. Thx. For belly tank bikes:  For no belly tank:  Thanks Mark, I'll look it up
