January 30, 2026, 02:05:51 AM *
Author Topic: When is an Interstate a GL1500FT  (Read 2607 times)
daytona
Port Orange, FL
« on: November 17, 2009, 02:41:29 PM »
and not a CF? ???
Just started!
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: November 17, 2009, 05:01:18 PM »
When it is a Gold Wing.
daytona
Port Orange, FL
« Reply #2 on: November 17, 2009, 05:46:23 PM »
Must be a typo error! I thought maybe a euro model.
Specifications: 1999 Valkyrie Interstate
Model: GL1500FT
Engine Type: 1520cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke: 71mm x 64mm
Compression Ratio: 9.8:1
Valve Train: SOHC: two-valves per cylinder
Carburetion: Six 28mm diaphragm-type CV
Ignition: Solid-state digital
Transmission: Five-speed
Final Drive: Shaft
Suspension Front: 45mm inverted telescopic fork; 5.1 inches travel
Rear: Dual shocks with five-position spring preload adjustability; 4.7 inches travel
Brakes Front: Dual disc with twin-piston calipers
Rear: Single disc
Tires Front: 150/80R-17
Rear: 180/70R-16
Wheelbase: 66.5 inches
Seat Height: 28.7 inches
Dry Weight: 771.0 pounds
Fuel Capacity: 6.9 gallons, including 1.1-gallon reserve
Colors: Black, Pearl Dark Green/Metallic Gray, Black/Red
Pricing: (US) $15,499 - $15,999
California version differs slightly due to emissions equipment.
Just started!
X Ring
« Reply #3 on: November 17, 2009, 07:59:57 PM »
Dunno but when I googled it, I kept coming up with oil filters for a Gold Wing GL1500FT.
« Reply #4 on: November 17, 2009, 10:05:27 PM »
They both use the same oil filter. There are many generic filters that fit, anybody got that oil filter and generic parts link? hoser
« Last Edit: November 17, 2009, 10:09:20 PM by Hoser » Logged
Madmike
Campbell River BC, Canada
« Reply #5 on: November 18, 2009, 04:50:47 PM »
http://www.jkozloski.com/generic_parts.htm
http://www.rattlebars.com/valkfaq/oilfilters.html
« Last Edit: November 18, 2009, 04:52:54 PM by Madmike » Logged
