December 15, 2025, 08:52:35 PM *
Author Topic: Front turn signal  (Read 2849 times)
Rdaugherty
« on: November 23, 2018, 09:53:29 PM »
How to access  front turn signal wiring ? Trying to make my fog lights with built in turn signals work . Need to tap into signals
« Last Edit: November 23, 2018, 09:55:00 PM by Rdaugherty » Logged
Kidd
Sedona
« Reply #1 on: November 24, 2018, 06:42:21 AM »
Under the seat , that's what I did
DLR lights  connect via cowling  , no directions with lights ?
« Last Edit: November 24, 2018, 06:46:06 AM by Kidd » Logged
« Reply #2 on: November 25, 2018, 05:04:15 AM »
Yes much better to go under the seat the wiring harness goes from next to the battery and you can tap off of that but you will need an adapter to do it. Not because of being able to tap into the wire but because of how the turn signals and the electrical system is setup. You need to search a bit and see whats involved otherwise you wont be happy.
http://www.valkyrieforum.com/bbs/index.php/topic,85641.0.html
This link will explain a bit and you can do some more research and get some answers
« Last Edit: November 25, 2018, 05:11:01 AM by Robert » Logged
Moofner
Colorado Springs, CO
« Reply #3 on: December 03, 2018, 04:35:28 AM »
Under the seat is the easiest but you could also tap into the main wiring spool going to the instrument cluster. I'd be reluctant to cut into the wrap there so take it slow and seal it back up if you do.
There are two good controller solutions out there. Kidd uses a different setup (can't remember the name) to the Admore style . Either will be fine if your signals don't work with a direct splice.
2003 Valkyrie "Ricky's Bike"
2014 Valkyrie "The Gypsy Bride"
