December 31, 2025, 09:52:22 PM *
Author Topic: Clutch  (Read 2147 times)
DIGGER
« on: December 03, 2018, 06:55:53 PM »
Slack in clutch lever.   Clutch lever almost all the way in before disengaging.     Any adjustment anywhere?
« Reply #1 on: December 03, 2018, 06:56:33 PM »
Dont think so.
JimBob
Diamondhead, MS airport (66Y)
Mississippi Gulf Coast- Hancock county
« Reply #2 on: December 03, 2018, 07:07:31 PM »
Hi Digger!
The Valk has a hydraulic clutch actuator.
My guess is that there is some air in the clutch line (tube).
You can bleed the clutch line, just like a brake line.
The bleed nipple is roughly on the bike centerline, above the rear of the transmission housing. There is a tube sticking up with the bleed nipple on the end of it.
There's probably a bunch of posts regarding the proper procedure.
I hope this helps!
Jim
Presently running:
'97 Valkyrie Tourer, '99 Valkyrie Interstate
'08 Buell 1125R, '06 Buell XB12X Ulysses, '06 Buell XB12S Lightning
'95 Suzuki GN125, '85 Suzuki GN250, '80 Suzuki TS125, '80 Suzuki TS250
Projects: '04 Buell Firebolt, '00 & '04 Buell Blasts, '74 Suz TM400, '78 Suz TS185
RWhitehouse
« Reply #3 on: December 03, 2018, 08:23:44 PM »
The hydraulic clutch is self-adjusting, just like hydraulic brakes are. It works the exact same way.  Air in the system will make the lever mushy.
As said the bleed nipple is on the left side, look just above and inboard of the alternator cover.  Use the exact same procedure for bleeding brakes.
If it's slowly gotten worse over time, the master cylinder may need to be rebuilt. Not difficult or expensive and kits to do so are readily available aftermarket or get the parts from Honda. Check the slave for any leaks- it's on the center rear of the engine, directly in front of the rear tire. If there's any moisture, rebuild the slave also.
pancho
Bonanza Arkansas
« Reply #4 on: December 04, 2018, 03:08:48 AM »
When I had that problem DIGGER, it was the slave leaking. Look at the slave on the clutch cover under the bike, if it is leaking, it will probably be visible running down the case,,, making a mess of the silver paint Honda used on that cover!! tickedoff
Check the fluid level in the master cylinder to see if it is down,, if so it is leaking somewhere, if not you are probably sucking air in the master.
« Last Edit: December 04, 2018, 03:16:53 AM by pancho » Logged
flash2002
Montreal, Que
« Reply #5 on: December 04, 2018, 03:23:12 AM »
There is a bushing in the lever that can be worn out and causing the problem. If that's not the problem, take the master and slave apart and clean and rebuild that way you know all is good.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: December 04, 2018, 03:29:08 AM »
Sludge in the master cylinder can also cause this.
Jersey
VRCC #37540
Southern Maryland
« Reply #7 on: December 04, 2018, 11:49:37 AM »
Good practice is to replace all of the hydraulic fluids (Front/Rear Brakes & Clutch) every two years.  Flush the system with fresh fluid until they run like new.
Jersey
DIGGER
« Reply #8 on: December 04, 2018, 12:50:00 PM »
Thanks for all the information
Big Rig
Woolwich NJ
« Reply #9 on: December 04, 2018, 06:03:31 PM »
So not flushing the clutch system in 19 years is a bad thing???  Roll Eyes Roll Eyes
« Reply #10 on: December 05, 2018, 01:58:41 AM »
Not yet it seems Smiley
« Reply #11 on: December 05, 2018, 08:16:24 AM »
That bushing is brass.  I've found it worn elliptical and dry.  Periodic lube will extend it's life.
pancho
Bonanza Arkansas
« Reply #12 on: December 07, 2018, 07:26:20 AM »
Dumped this out of a GW front brake.
DIGGER
« Reply #13 on: December 07, 2018, 01:11:55 PM »
checked reservoir and it is a little down.    no leaks I can see under the bike.    what do you use for clutch reservoir oil?
« Reply #14 on: December 07, 2018, 02:56:41 PM »
brake fluid Dot 3
DIGGER
« Reply #15 on: December 07, 2018, 04:34:20 PM »
brake fluid Dot 3
« Reply #16 on: December 07, 2018, 05:00:40 PM »
brake fluid Dot 3
Valkyrie brakes and clutch take dot 4. Just in case this is for a Valkyrie
« Last Edit: December 07, 2018, 05:04:47 PM by Chrisj CMA » Logged
« Reply #17 on: December 07, 2018, 06:33:32 PM »
brake fluid Dot 3
Embarrassed oops
DIGGER
« Reply #18 on: December 08, 2018, 08:07:26 AM »
Got it.   Dot 4.   Thanks.  Havent bought the fluid yet
indybobm
Franklin, Indiana VRCC # 5258
« Reply #19 on: December 08, 2018, 09:47:39 AM »
A lot of places do not have Dot 4 fluid. They have Dot 3 & 4 fluid. Walmart, autozone, etc.
So many roads, so little time
VRCC # 5258
« Reply #20 on: December 08, 2018, 04:49:38 PM »
get the new DOT 4 LV. Last longer has a higher wet boiling point.  better consistent feel wider range of temps. used in the brakes provides a very firm feel.
9Ball
« Reply #21 on: December 09, 2018, 05:06:42 AM »
brake fluid Dot 3
DOT 3/4 is ok.  Never DOT 5.
DOT 3 and 4 or a product compatible labeled 3/4 are all ok.  Synpower 3/4 is what I use in all my bikes and I flush mine every year using speedbleeders.  Makes it an easy job.  I have a mityvac too that works well on new hydraulic lines to get all the air bubbles out.
https://www.walmart.com/ip/Valvoline-DOT-3-and-4-Brake-Fluid-12-oz/19897940?wmlspartner=wmtlabs&adid=22222222222024362561&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=t&wl3=10359513921&wl4=pla-4578847476194648&wl5=&wl6=&wl7=&%20wl10=Walmart&wl12=19897940_10000002955&wl14=valvoline%20synpower%20brake%20fluid&veh=sem&msclkid=62f77881e2ae1f30cda3248cfc2b4da2
Advance Auto or Autozone has it much cheaper than Walmart.
« Last Edit: December 09, 2018, 05:08:18 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Jersey
VRCC #37540
Southern Maryland
« Reply #22 on: December 09, 2018, 07:13:45 AM »
Not knowing much about the impact of viscosity of brake fluid on actual use here's some interesting stuff I found.  Thought others might appreciate.
https://www.youtube.com/watch?v=SdnSlBG71G4
https://www.youtube.com/watch?v=YpMcG3WiN8M
« Last Edit: December 09, 2018, 07:21:05 AM by Jersey » Logged
Jersey
Valker
Wahoo!!!!
Texas Panhandle
« Reply #23 on: December 09, 2018, 11:16:35 AM »
The different types (DOT 3, 4, 4.1, etc) doesn't mean their viscosity, but just what the formulation is. DOT 5 and 5.1 is synthetic and can't mix with the others.
Jersey
VRCC #37540
Southern Maryland
« Reply #24 on: December 09, 2018, 11:21:48 AM »
From what I researched, each of these do have different viscosity and ONLY the DOT 5 is different and can't be mixed.  Apparently the 5.1 is Glycol and can be mixed with the others.  At least this is what found in my research, but I could be wrong.
Jersey
ridingron
Orlando
« Reply #25 on: December 09, 2018, 11:23:24 AM »
The story we got at work was that 3 & 4 were interchangeable. 4 has a higher boiling point.
Jersey
VRCC #37540
Southern Maryland
« Reply #26 on: December 09, 2018, 11:55:29 AM »
Checking the Federal Regulations DOT 3, 4, & 5.1 are NON-Silicone based and can be mixed.  Only DOT 5 is Silicone based and can't be mixed with the others.  Interesting reading: https://www.law.cornell.edu/cfr/text/49/571.116
Jersey
Valker
Wahoo!!!!
Texas Panhandle
« Reply #27 on: December 09, 2018, 12:47:00 PM »
Thanks for clearing that up.
« Reply #28 on: December 09, 2018, 01:23:25 PM »
All brake fluid is synthetic and has been for a long time.
indybobm
« Reply #29 on: December 09, 2018, 01:42:51 PM »
And then there is this. Is it closer to DOT 3 or DOT 4? I would guess DOT 4.
« Last Edit: December 09, 2018, 01:50:35 PM by indybobm » Logged
VRCC # 5258
JimBob
« Reply #30 on: December 09, 2018, 07:03:53 PM »
Hmmmm..... How come every time there is something simple and it works...... someone has to come along and make it complicated?
Presently running:
« Reply #31 on: December 10, 2018, 04:46:07 AM »
highest wet boiling point is best to use.  ATE and Motul come to mind as highest but very $$$
https://www.lelandwest.com/brake-fluid-comparison-chart.cfm
http://www.stealth316.com/2-brakefluid.htm
http://www.stoptech.com/technical-support/technical-white-papers/brake-fluid
I've been using Pentosin DOT 4 LV.   which comes in metal cans except for the plastic cap.
http://www.pentosin.net/specsheets/Pentosin_Dot4_LV.pdf
http://www.pentosin.net/f_brakefluid.asp
DIGGER
« Reply #32 on: December 10, 2018, 06:51:38 PM »
Ok....not being much of a mechanic I took my Valkyrie with the clutch problem to Honda of Houston to get  the clutch problem repaired.    They found the clutch lever worn, the bushing in the clutch lever disentigrated and very eliptical.   They replaced these parts, flushed out the old clutch fluid and put in new,   also put in 6 new sparkplugs.   1 1/2 hr wait, $298.00 and I was out the door with a new clutch feel.
9Ball
« Reply #33 on: December 11, 2018, 02:14:25 AM »
That’s absolutely true...man made.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
flash2002
Montreal, Que
« Reply #34 on: December 11, 2018, 03:57:22 AM »
Told you so, that was my first guess.
DIGGER
« Reply #35 on: December 11, 2018, 06:29:23 PM »
I want to thank everybody for your thoughts and ideas with my clutch problem    it helped understand my problem and was able to talk to the dealer service dept about the problem.    Honda of Houston is a goo dealership.   I recommend them
pancho
Bonanza Arkansas
« Reply #36 on: December 12, 2018, 10:31:16 AM »
1 1/2 hr wait, $298.00  As long as you're happy DIGGER
« Last Edit: December 12, 2018, 10:44:08 AM by pancho » Logged
« Reply #37 on: December 12, 2018, 11:11:12 AM »
many on the GW GL1500 sites indicate that the clutch fluid cannot be completely flushed out and they recommend to actually pulling the slave cylinder off and cleaning it out. however after many yrs of not even flushing the system at all.
