August 01, 2025, 03:23:59 AM *
Author Topic: Any Interstate owners using a Breakaway throttle lock?  (Read 1341 times)
pocket aces
Tampa, Fl
« on: December 14, 2018, 09:48:18 AM »
Their web site says fits all models exempt Interstate.  Roll Eyes
« Reply #1 on: December 14, 2018, 10:46:14 AM »
Probably has to do with the differences in how the throttle cables exit the housing.
Andy Cote
Windham, Maine
« Reply #2 on: December 14, 2018, 10:52:48 AM »
I believe it is related to the location of the throttle cables.  I do not have this one but purchased the one from MADCO.  It is extremely well made and works as it should.  I installed in conjunction with ISO grips.  MADCO's website is currently off but you couldn't order from the site anyway.
I can't find the e-mail address but the phone number is 619-423-5693
Motorcycle Accessory Design Co.
P.O.Box 31
Imperial Beach, CA     91933
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
pocket aces
Tampa, Fl
« Reply #3 on: December 14, 2018, 10:58:33 AM »
That's what I was thinking. Let me give MADCO a call. Thanks  cooldude
« Last Edit: December 14, 2018, 11:03:48 AM by pocket aces » Logged
SCain
Rio Rancho, NM
« Reply #4 on: December 14, 2018, 12:10:15 PM »
I have the MADCO throttle lock on my IS, very well made works great.
Steve
pocket aces
Tampa, Fl
« Reply #5 on: December 14, 2018, 12:13:14 PM »
Will the MADCO work with Kuryakyn grips?
« Reply #6 on: December 14, 2018, 12:17:02 PM »
Yes.  Here is a picture from his website (on Hondas).
I have two sets of them on my interstates.  It's been years, since I put them on.  Remember, the Kuryakyn ISO grips specific for Valkyrie are like 6 1/2 inches long.  And the throttle boss (above the grip) uses up a bit of handlebar.  I believe the kit comes with that plastic spacer (to screw into the bottom of the throttle sleeve), so you don't end up with a half or three-quarter inch of empty ISO grip on the ends.
Now if you have a standard set of Universal ISO grips that are 5 3/4" long (which also fit Valks), you won't need the spacer.
Notice in the picture the length difference in the stock (plain) vs Kury ISO grips (which are the long ones).
I always recommend not adding any extra weight to your bike key, the weight and wind adversely affect the Valk ignition switch over time.  But that little aluminum hex key (to adjust the throttle lock tightness) weighs a couple grams, and is on a ring on my valk ignition key, to keep it handy (and not get lost).
Over time, it needs snugged up just a bit.
« Last Edit: December 14, 2018, 12:34:59 PM by Jess from VA » Logged
Andy Cote
Windham, Maine
« Reply #7 on: December 14, 2018, 03:05:55 PM »
Jess
were you able to access the web site today?  I keep getting an out of service page,
Andy
« Reply #8 on: December 14, 2018, 04:45:08 PM »
Jess
Andy
No I wasn't, I found those pictures in a search, going to images.  Same pictures as on his website when I bought mine over 10 years ago.  As I recall, he is a one-man operation and a very nice guy.  I hope it's only a temporary problem.
Flrider
Jack
Kissimmee FL
« Reply #9 on: December 15, 2018, 07:04:07 AM »
Vance
I run a breakaway on my interstate, it works and I am extremely happy with it.
Quality product, had it on other bikes before and never disappointed.
It also works with Kuryakyn grips which I also have on the interstate.
jbrooks
Oliver British Columbia
« Reply #10 on: December 17, 2018, 01:55:21 PM »
I also have the breakaway on my Interstate. Works well. Takes a little time to get adjusted.
