March 29, 2026, 07:41:57 PM *
Author Topic: alternator cover repair  (Read 699 times)
malito650
« on: December 15, 2018, 01:58:01 PM »
with the mounting tab split in half on my 97 tourer alternator cover, is there any clever repair figured out by any of our valkyrie modification wizards ?  I'm sure there are several tricks figured out over the years.
da prez
Wilmot Wi
« Reply #1 on: December 15, 2018, 02:11:09 PM »
  The cover is ABS plastic. O N L Y  ABS black plastic glue will work. I use MEK for cleaning and in some cases bonding. MEK will dissolve the plastic , so be careful. If you have the old part , it can be glued on , but will not be as strong. MEK weld is better , but more difficult. Make sure the parts fit and you know the way it will go together.  Dab MEK on both pieces and put together wet. I clamp in place and let it sit for a day. It will be stronger than glue.
                                             da prez
« Reply #2 on: December 15, 2018, 02:48:56 PM »
best to use a two part epoxy for ABS. this works very well and avail most hardware stores
https://www.pcepoxy.com/products/
« Reply #3 on: December 15, 2018, 03:36:16 PM »
Or buy a new one ...... I have three  coolsmiley just in case 2funny
« Reply #4 on: December 15, 2018, 04:02:50 PM »
Wish I had thought about it.   Just sent a beauty to a salvage auction.....   coolsmiley
(Willow, it was your's.)
« Last Edit: December 16, 2018, 01:20:20 AM by Rams » Logged
