December 31, 2025, 05:01:39 AM *
Author Topic: Interstate LED headlight bulb - which one to buy?  (Read 2591 times)
nogrey
Nampa, Idaho
« on: December 19, 2018, 04:20:48 AM »
Just wondering what LED lamps everyone is using and the level of satisfaction with your selection. I searched the boards and found some recent (July 2018) conversations. Valkorado is happy with the ones he picked and I’m leaning that direction. Since they are improving LED replacement bulbs daily, was just wondering if someone had come up with the “bomb”.
Valkorado, Thanks for the link. One last question for you. Do you still have both high and low beams. I just watched a You Tube video where the guy said he only had high beams after replacing his bulbs. Probably not the same bulbs you suggested, but I want to be sure before I purchase.
Yup.  The lo beams are amazing, the hi beams are indescribably bright.  You'll want to hold your halogens up to these (if and) when you get them.  It is then fairly obvious how to align the bulbs, pretty much straight up and down.  There are alignment tic marks that show you where straight up is.  You will not regret the upgrade.
Here is another vendor.
https://www.ebay.com/itm/For-Philips-G7-H4-HB2-9003-8000lm-LED-Headlight-Hi-Lo-Beam-Conversion-Kit-Bulbs/323209255650?epid=7003967324&hash=item4b40c5dae2:g:blQAAOSwvjdZU0ih
Just found a better deal here.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F202357583089
SCain
Rio Rancho, NM
« Reply #1 on: December 19, 2018, 05:41:45 AM »
I followed Valkorado's suggestions as well, I really like the type of light better. I removed my fairing so I could mount the black box, there is a flat spot on the back side of the headlight housing where I used dbl face tape to secure the boxes.
Steve
« Reply #2 on: December 19, 2018, 06:02:17 AM »
Wow, you made a project out of it!  I took the lazier approach, and used zip ties to attach the ballasts to the upper fork tubes, and tucked 'em in behind the fairing.
SCain
Rio Rancho, NM
« Reply #3 on: December 19, 2018, 07:55:35 AM »
LOL, fairing comes off pretty easy (10 min), while I had it off I modified the front turn signals to LED's, followed Steel Cowboys turn signal change to HD pancake style signals.
Steve
« Reply #4 on: December 19, 2018, 05:31:06 PM »
I actually just looked 2 nights ago after coming back from my weekly GWRRA meeting with the boys.
They use one for their GL1800 from Socalmotogear.com that they swear by for their bike. When I asked and talked about on H4 version for my IS, turned out they are using an H7 (?), and the discussion was there isn't any good one yet for one that has a dual beam (Hi/Lo).
That's why I searched the forum for the discussions from this year about replacement head light bulbs. I think it's going to come down to how much to spend. Do you buy one bulb at $65, or a set for $40, and see which one is better.
But since I bought a higher watt bulb earlier in the year, along with one of BonS's head light relayed direct power wires (Smart Switch), for the bulb, so it gets its power direct from the battery. I do very light riding in the dark, so am also more interested in being seen.
Ken Tarver
North Mississippi
« Reply #5 on: December 21, 2018, 01:28:56 PM »
Pathfinder is great bulb
Cyclops too
On amazon I got one for friend called Sealight. 6000 Lumen hi/lo
6000K color (white not bluish light)
Looks great
And with the 6000 lumen spots in the Cobra bar it is freaking awesome.
Ken
Gideon
Indianapolis, IN.
« Reply #6 on: December 21, 2018, 02:22:31 PM »
Replaced Head Light Bulb on my "Fast Black" 2003 with a Pathfinder 4H 6000K Bright White LED Bulb. Also replaced the H3 Halogen Bulbs in my twin Spotlights with 50 Watt, H3 LED 360 Bulbs from Pathfinder. Bright White -6000K.   cooldude
Paladin528
« Reply #7 on: December 24, 2018, 05:49:10 AM »
these
https://cyclemax.com/inc/sdetail/gl1500_new_style_pathfinder_led_h4_headlight_kit/167424/358815
BINOVC
Southaven, MS
« Reply #8 on: September 13, 2019, 11:48:45 AM »
@Valkorado,
Are these the same bulbs you used?  Your links no longer work.  For '99 I/S.
Still working ok?
https://www.ebay.com/itm/H4-HB2-9003-LED-Headlight-Kit-Hi-Lo-Beam-Conversion-Bulbs-For-Philips-G7-8000LM/264109884185?hash=item3d7e2d0319:g:ziEAAOSwJ3RcJtoQ
Thanks!
« Reply #9 on: September 14, 2019, 04:25:18 PM »
@Valkorado,
Still working ok?
Thanks!
Sorry,  just saw this.  Those are a bit different.  I just did another search,  these are the exact bulbs I'm using.  Seems they have went up a bit.  They're still working great!
https://www.ebay.com/itm/NEW-Lumileds-H4-9003-HB2-Car-LED-Headlight-Replacement-Bulbs-COB-Kit-6500K-White/222650109666?epid=826033830&hash=item33d6fb0ee2:g:KJcAAOSwlRZZwN9u&vxp=mtr
« Last Edit: September 14, 2019, 04:37:57 PM by Valkorado » Logged
ridingron
Orlando
« Reply #10 on: September 15, 2019, 10:43:06 AM »
The ad is for a direct H4 head lamp. Is the I'state an H4 lamp?
« Reply #11 on: September 15, 2019, 10:49:47 AM »
Yes.  Bulb H4 #9003
ridingron
Orlando
« Reply #12 on: September 15, 2019, 11:24:53 AM »
I'm somewhat confused.
 Partsfish shows the headlamp part number the same as an ST1100, 34901-MS2-672 . The ST1100 is not an H4 lamp. It is very similar but the 3 tabs are at different angles than an H4.  The ST1100 headlamp housing has the slots for the tabs cast into the plastic housing. It is a US DOT thing as the European ST lamp housing is cast for an H4.
« Reply #13 on: September 15, 2019, 11:40:15 AM »
Yes.  Bulb H4 #9003
Technically, no. The stock OEM bulb is different. But most everyone uses the H4 by breaking 2 of the tabs.
ridingron
Orlando
« Reply #14 on: September 15, 2019, 11:58:23 AM »
OK. Same as the ST folks do. Thanks for the clarification.
« Reply #15 on: September 15, 2019, 12:16:35 PM »
Yes.  Bulb H4 #9003
Sorry, I should have clarified.  (Breaking tabs off since 2005)
Paladin528
« Reply #16 on: September 16, 2019, 08:38:28 AM »
I got a set of LED lights from SuperbrightLEDS.com Integrated controllers so no black box to worry about.  Plug and play.
I am not 100% happy with the beam pattern but they are really quite bright
« Reply #17 on: September 16, 2019, 09:31:45 AM »
I have a similar set I installed then removed some time ago as the pattern was less than optimal.  Now my needs have changed as I run them in my spot fixtures all the time with Josh's "Dragon's Eye" main headlight, all on high daytime for safety.  Plus 2 conventional LED spot fixtures.  Sw them to low only at night with oncoming traffic.  I never get flashed and I'm definitely visible for safety daytime.  There's enough light down the road both hi and low beams for deer visibility.  Not as bright as it used to be running H4 halogens but now all 5 lights draw the same as the one 130/90 headlight used to on high beam.  Preserving my alternator now - had to replace it last year with so much load.
BINOVC
Southaven, MS
« Reply #18 on: October 28, 2019, 10:33:23 AM »
@Paladin528, I’m looking at the Superbright ones:
https://www.superbrightleds.com/moreinfo/motorcycle-high-beam-and-low-beam-headlight-bulb/motorcycle-h4-led-fanless-headlight-conversion-kit-with-compact-heat-sink-2000-lumens/3930/8566/?make=32&model=2656&scc_id=1940&year=1998
Are these what you have?
Do they fit in the Interstate housing as-is, or do you need to cut off tabs like on the other 9003/H4 bulbs? The guy at Superbright really didn’t know...
 Superbright also suggested I get the load resistor. I told them I don’t have to worry about a “bulb out message” on my “dashboard” , but they still suggested it.
Is their heat sink removable, or does this affect installation (fitting of the rubber boot?).
I’m also looking at the Cyclemax Pathfinder that some strongly recommend, wondering what makes it worth nearly 2x.  Comments welcomed.
« Last Edit: October 28, 2019, 02:03:35 PM by BINOVC » Logged
NighthawkVTX
Gainesville, Fl
« Reply #19 on: October 29, 2019, 08:37:31 AM »
I HIGHLY recommend Electical Connections  LED bulbs.
 I have posted pictures of road views with these mounted on my IS. The difference is incredible. They are easy to install just make sure you get an H4  adapter
If at first you don't succeed, then perhaps skydiving isn't for you
BINOVC
Southaven, MS
« Reply #20 on: November 01, 2019, 02:23:15 PM »
I looked up your thread and your link to the bulbs.
https://electricalconnection.com/index.php/product/led-headlight-bulb-h4/
I called electricalconnection (spoke with KC) to ask a few questions (may be of interest to others):
1) Warranty? 2 years
2) Need any adapters? yes, their part # 2510 ($13/pair)
3) Legal?  Legal in TN but don't know about anywhere else.
4) Need to trim rubber boot? No.
5) What is 360 degree beam angle?  Emits light a full 360 degrees.
6) What is adjustable pitch angle?  They provide an allen wrench to make adjustments to the angle of the bulb, but adjustment not needed for I/S.
So I still haven't decided.  Undecided
DarkSideR
Pueblo, Colorado
« Reply #21 on: November 17, 2019, 05:19:10 AM »
Which bulb did you go with?
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
