August 21, 2025, 09:06:21 PM *
Author Topic: lights  (Read 1200 times)
Funbaldguy
grand blanc Mi
« on: December 21, 2018, 01:54:59 PM »
is there something that is plug and play to make the turn signals work as running lights? or possibly brake lights as well? I hope so. please Grin let me know
« Reply #1 on: December 21, 2018, 02:54:16 PM »
My interstate came with a small black box under side cover (or seat) that makes my rear turns into run-turn-brake lights (about the size of a deck of cards).  I cannot remember the name, but it is a company that does them.  I think several companies make them (Kuryakyn?).  And this is with the OE 1156 single filament bulbs.
You have to get red lenses for the signals to be full-time runs.  Or paint the ambers with Testors red paint.
I also have a single row of LEDs on a plate frame that are run/brake lights. The single row is low, so it doesn't interfere with the plate light.
This interstate has no trunk, so I have the std/tourer tail light with the knockout on the fender removed.
I like having 4 running lights and brake lights.
« Last Edit: December 21, 2018, 02:55:50 PM by Jess from VA » Logged
« Reply #2 on: December 21, 2018, 04:42:51 PM »
Electrical Connections sells an LED kit that installs in the rear turn signals. I've installed 2 sets for friends and they work very well.
WintrSol
Florissant, MO
« Reply #3 on: December 21, 2018, 04:56:44 PM »
https://electricalconnection.com/index.php/product/rear-turn-signal-conversion-kit/
Funbaldguy
grand blanc Mi
« Reply #4 on: December 22, 2018, 03:23:22 AM »
Thank you for the info cooldude. I will check into this product more. it looks like what I described.
WintrSol
Florissant, MO
« Reply #5 on: December 22, 2018, 11:46:59 AM »
I'm pretty sure it uses the filament of the turn signals for 'ground', so if you have replaced yours with LEDs, it likely will not work.
« Reply #6 on: December 22, 2018, 02:44:45 PM »
Not this kit. It's independent of the turn bulb.
WintrSol
Florissant, MO
« Reply #7 on: December 22, 2018, 05:25:55 PM »
The one I linked does connect to the turn bulb, per the documentation on the site: https://electricalconnection.com/wp/wp-content/uploads/2016/02/tsk.pdf
flash2002
Montreal, Que
« Reply #8 on: December 23, 2018, 05:35:39 AM »
I got something like this for the back of my bike and painted the lens with clear red model paint. Because they are front flashers they have both flasher and park.
                                      https://www.ebay.com/itm/1999-2000-2001-Honda-GL1500-CF-Valkyrie-FRONT-TURN-SIGNAL-LIGHT/382615244660?epid=27025395092&hash=item5915a54f74:g:muoAAOSwn7Rb2yuP:rk:32:pf:0
WintrSol
Florissant, MO
« Reply #9 on: December 23, 2018, 06:55:21 PM »
It occurs to me that, with a simple change, it could be made to not need the filament as a ground. All they need add is a ground connection, and a depletion mode MOSFET transistor that is fully off when the gate approaches 12V.
