March 29, 2026, 02:19:40 PM *
Author Topic: Done for the Winter  (Read 521 times)
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
« on: December 23, 2018, 04:40:20 AM »
I have been trying to make room at my In-laws garage to store my bike for the Winter.  My wife and I finally cleared out enough room so I took a short ride yesterday it's all of maybe 6 miles but I enjoyed it thoroughly!  I needed to make a bike of room in my garage so I could service my snow blower yesterday I started working on the blower 1st on the list was to remove and clean the carb this went smooth no issues at all main issue was a stuck float.  Second was change the oil glad I did this it seems as though it was low on oil so I glad I took care of this.  Third thing was to change the belts which were apparently original and about 24 years old I'm impressed they still worked!  Unfortunately I have not been able to find the correct belts I did find one that seems to match up but the other I have searched high and low with no luck.  Sadly after working on this my back has been killing me!  I'm hoping to both finish the repairs today it looks like I may have to take a drive to a friends hardware store up in Florida NY I'm sure he will have the belts he has everything.
« Reply #1 on: December 23, 2018, 06:20:44 AM »
my mother in laws 1974 snowblower, a Sears Homelite in blue/white,  belt is OEM original from 1974 and still not snapped, although a new engine was in order over 10 years ago.   Not sure anything made in the past 20 years compares to it as well unless spending 1 grand or more on a new snowblower.  Probably was the biggest/baddest snowblower of its time as well but average as compared to size nowadays, but made to last.  I use it now since unable to put electric push button start on the design and the pull rope is VERY, VERY long since mother in law age 76 and unable to pull the rope back to start it anymore.  She had trouble starting it 20 years ago not due to age more so arms length being average 5'3" or so height, even I have issues with such a needed LONG pull rope to get it going.  Reminds me I should get it as well over to my house for winter in case we EVER get any snow this winter and also been a few years since last changed oil on it using it like 1-2 times every year is all.
DGS65
Nanuet, NY
« Reply #2 on: December 23, 2018, 07:14:30 PM »
I feel the same about the oil but I really don't remember the last oil change I'm sure it was well overdue! I installed new belts today and it started right up and burnt one of the belts.  I suspect 24 years ago the belts were a little bigger then the current model with the same part number.  I was clearly tight when installing it and it just didn't process that there is a break on the auger pulley and with the belt as tight as it was there was no way for it to slip so it just burnt up in seconds.  I will try to find a belt 1" longer tomorrow morning I would really like to finish this before I go on vacation.
While I'm heading Florida I won't get to ride a bike but the good news is my mother bought almost the same Corvette as me so I will at least get to drive her car while I'm there Smiley
« Reply #3 on: December 24, 2018, 12:24:11 PM »
Anyone north of the Ohio river need a snowblower?   I've got a dandy i'd make someone a good deal on.
Won't need it where I'm going......
27", 8 hp Sears craftsman.   electric 110v start.
« Reply #4 on: December 25, 2018, 08:48:20 AM »
wow, burning a belt, must have been way too tight then I assume since new belt should not do that ever.  Never burnt a belt, but snapped one once due to age long, long ago was time to replace.  Am sort of surprised though that 40+ year old OEM belt is starting to fray a smidge on the edges, but still running decent the old blue Sears Homelite snowblower.  Yah,  I do not believe oil on items you use 2-3 times per year for 30 minutes each really breaks down that much just sitting inside, but moisture more so from sitting am sure does break the oil down some.  Probably should change it has been a few years since ONLY takes like 20 ounces cheap insurance and easy to do.  I know when my mother in law had the old snowblower,  she wanted it changed EVERY single year even though when poured it out the next season before use it was like brand new clean after 2-3 uses tops is all all winter long.
