January 30, 2026, 02:07:22 AM
Socket needed.
Topic: Socket needed. (Read 2407 times)
Grumpy
Tampa, Fl
Socket needed.
November 18, 2009, 09:37:49 PM »
Does any one have a socket that fits the rear swing arm lock nuts, I have the allen for the center, but need the one for the lock.
Looks like it has an offset for the wrench, as you have to hold the center allen, while torquing the outer lock nut.
DFragn
Re: Socket needed.
November 19, 2009, 09:08:27 AM »
HDL has them, probably as a drop shipment for < $60.00. That's $15.00 to $20.00 less then I've seen elsewhere.
http://www.hondadirectlineofshadyside.com/stores/product.asp?pid=1387&str=2
Re: Socket needed.
November 19, 2009, 10:00:18 AM »
I got one...
Last Edit: November 20, 2009, 07:48:49 AM by hubcapsc
Grumpy
Tampa, Fl
Re: Socket needed.
November 19, 2009, 07:56:41 PM »
Quote from: DFragn on November 19, 2009, 09:08:27 AM
Thanks, I will order one from them.
