March 29, 2026, 02:19:39 PM *
Author Topic: 9H Ceramic Coating on my Polished Wheels  (Read 968 times)
Alberta Patriot
« on: December 25, 2018, 09:03:47 AM »
I ordered this to experiment with on some scrap aluminum sheet metal that I will polish:
https://www.amazon.com/Ceramic-Coating-Anti-Scratch-Exterior-Hardness/dp/B0757LCVL6/ref=sr_1_fkmr0_2?ie=UTF8&qid=1545759825&sr=8-2-fkmr0&keywords=mr+fix+KOBWA+9H+Car+Ceramic+Coating+Kit
I know this is most likely krap, but what the heck, why not try.
I did polish what used to be my corroded wheels to a very acceptable shine, but because I removed all signs of clear coat, they need more upkeep now.
https://www.youtube.com/watch?v=XBJ15eq2f6Y
https://www.youtube.com/watch?v=2UZcbdeUVWQ
« Reply #1 on: December 25, 2018, 09:38:08 AM »
I have used this kit on my wheels. using the sealer works very well. zero corrosion in over a year. the closer to a mirror finish there is actually less corrosion/dullness that happens.
https://www.topoftheline.com/rolmetpolkit.html
« Reply #2 on: December 25, 2018, 01:15:17 PM »
Someone else posted about using the same product (different name) on his bike. Comes out really nice, had pictures.
Nano polishers
Alberta Patriot
« Reply #3 on: December 25, 2018, 03:30:51 PM »
Nano polishers
I am about to remove the wheels to replace the tires so this would be a good time to do a final polish and the 9H Ceramic Coating. If it is good for about 2 years on a car's paint(with the proper product and method) I am pretty sure it will last me the time between tire changes.
However...saying that...there are fake products out there, so vetting the seller is important.
Anyway...pics and a review will be posted when done.
« Last Edit: December 25, 2018, 03:38:59 PM by 7th_son » Logged
signart
Crossville, Tennessee
« Reply #4 on: December 25, 2018, 06:07:06 PM »
Guys I've used this on my aluminum intakes for 20+ years. Tough stuff. Oil, gas, heat won't damage it. It should be great for wheels. Comes in gloss or satin. Only ten bucks, would do one wheel with several coats.
bscrive
Ottawa, Ontario
« Reply #5 on: December 25, 2018, 06:51:18 PM »
I have used Eastwood for several projects on my bike.  The paint is awesome to use, the paint is super durable and the spray cans are so good that anyone can do a professional job.  I don't paint much, but their products and spray cans make my painting look like a pro did it.
signart
« Reply #6 on: December 26, 2018, 06:55:52 AM »
My powder coater also uses this for intakes on high end restos and show cars. Doesn't yellow like powder coat under heat and gas/oil saturation.
I like the satin, gives a low sheen and you can't screw up if you follow directions.
I just finished one for my grandson's BBC intake
shortleg
maryland
« Reply #7 on: December 26, 2018, 09:10:12 AM »
  Silver powder coat with a  clear coat powder coat is great on wheels but
you have to remove bearings and make sure  coated knows how to avoid getting
powder in races for those bearings.
Alberta Patriot
« Reply #8 on: December 26, 2018, 02:31:02 PM »
I'm guessing the 9H nano coating is a lot easier. From what I've seen just hosing the rims down with just water and a quick microfiber wipe does it.
And as a booster every 6 months(I guarantee you will like this video) Wink
https://www.youtube.com/watch?v=rM0Y_6O4y-c
« Last Edit: December 26, 2018, 02:36:17 PM by 7th_son » Logged
