November 14, 2025, 05:23:08 AM *
Author Topic: Fast blinking blinker  (Read 892 times)
Mofla
San Antonio TX
« on: January 06, 2019, 06:16:00 PM »
For some reason my right blinker is blinking fast  ? Is that warning for possible failure? Or,,,,thanks
« Reply #1 on: January 06, 2019, 06:19:13 PM »
Is both the front and back working? If one is burnt out it will flash fast.
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
« Reply #2 on: January 06, 2019, 06:51:44 PM »
Sounds like you need to add Blinker fluid to slow it down.
WintrSol
Florissant, MO
« Reply #3 on: January 06, 2019, 07:37:28 PM »
Here's your source for Blinker Fluid: http://kalecoauto.com/index.php?main_page=product_info&cPath=9&products_id=22&zenid=iFJeSsF5k4G9epLLYD2cA3
But, yeah, make sure both signals are flashing at full brightness. You may just need to remove the bulbs and clean the sockets out.
« Reply #4 on: January 07, 2019, 04:14:27 AM »
              Just recently had a similar issue on a 2000 I/S my Brother-da prez-is refurbing for sale. The turn indicator switch was part of the culprit. Some serious then some more serious cleaning of switch and pulling each bulb-they all still worked-and a quick wipe and all is back to nermal. When I've had the fast flash thingy on my 99 I/S it was generally a bad bulb. Hope ya git yer issue sorted out. RIDE SAFE.
