November 14, 2025, 07:11:53 AM
Hyperpro Progressive Fork Springs
Topic: Hyperpro Progressive Fork Springs (Read 976 times)
dancnman
Houston, Texas
January 12, 2019, 06:58:15 AM »
I put the hyperpro springs last year and I am not satisfied with the way they handle. I used the mfg. oil fill settings I don't think it is the best. Has anyone used this spring and if so, can you tell me what and how much oil you used?
Reality is that thing which does not change simply because I choose to ignore it.
h13man
Indiana NW Central Flatlands
Re: Hyperpro Progressive Fork Springs
January 12, 2019, 07:15:53 AM »
I haven't heard of this brand before. I was able to purchase a set 0f Racetech #80 which is the lowest rate they offer from a fellow member here as he found them too stiff. These area single wound and I weighing in at 165 lbs. they seem harsh at 1st. but they broke in after about 5,000 mi. and do really great for two up traveling (400 lbs.+), loaded, etc. I use 10w Belray fork oil as their TRUE viscosity is rated @ 10w. As for a progressive spring, I used the PRORESSIVE brand on my 1100 Spirit 5 yrs./33,000 mi. under the same conditions and started getting soft near the end of the that time period. They were excellent improvement on the Spirit but...
January 12, 2019, 09:28:03 AM »
A long time ago, I paid (large) to have Progressive Suspension fork springs put in.
When done, it felt like there were no springs at all, hard as a rock.
It wasn't the springs, it was too much fork oil.
I don't care what the manual says (volume or level), if it's hard, take some out and it should get better.
Even if you end up a few ounces less than called for.
Also, later research showed that all fork oils (10wt or other) are not equal.
January 12, 2019, 12:59:38 PM »
I installed Hyper Pros in my '05 wing. Love them and when my current valk needs seals, I'll get another set. In the wing I set the oil level exactly to OEM specs using HPs supplied oil.
Bagger John - #3785
January 14, 2019, 06:09:24 AM »
I have them in my '99 Tourer. The bike is set up with an I/S trunk, tank and shocks and has the usual amount of additional chrome (mostly Hondaline and Kuryakyn, but a few assorted National Cycle and Show Chrome bits as well). It also has a Memphis Batwing and a full complement of electronics - gauges, CB and amateur radio transceivers.
Dressed in riding gear I'm around 240-245.
Used a mixture of Hyperpro and Maxima 15wt fork oil, slightly (1/4" or so) under the OEM fill level specs for each leg.
The stock springs had ~15K on them when I rebuilt the forks due to leaky seals. That said, handling is not harsh by any means but it's definitely more controlled. Feels good with a passenger too - I've taken a number in various weight ranges from 100ish to 200 and the front end never bottomed out.
=> InZane XXV
