November 14, 2025, 05:20:41 AM *
Author Topic: Fork seal driver  (Read 2204 times)
jackt
This is one of my babies
Central Kansas
« on: January 12, 2019, 07:08:24 AM »
97 standard and 99 standard
What size is the fork seal driver?
Do you have preference brand and/or part number?
jackt
2006 Shadow
1999 Standard (fast black)
1997 Bumblebee
2005 Gold Wing trike
h13man
Indiana NW Central Flatlands
« Reply #1 on: January 12, 2019, 07:18:44 AM »
I use the old seal up side down and a cheap clear yellow light weight mallet and carefully tap in the oiled new seal.
« Reply #2 on: January 12, 2019, 01:01:12 PM »
Motion Pro sells a fork seal driver that's adjustable.
RonW
Newport Beach
« Reply #3 on: January 12, 2019, 07:52:23 PM »
45mm. I just did my oil seals. Do not use All Ball seals. If you like, upgrade to Progressive Springs while you're at it.
2000 Valkyrie Tourer
Bagger John - #3785
« Reply #4 on: January 14, 2019, 05:58:17 AM »
Why?
RonW
Newport Beach
« Reply #5 on: January 14, 2019, 06:12:03 AM »
fitment issues, try read ..... Ok, took Grumpy's advice and ordered OEM fork seals.
RonW
Newport Beach
« Reply #6 on: January 14, 2019, 06:31:50 AM »
oh, something that might have relevance or might not. I tried the Seal Doctor and only ended up increasing the rate of leak. Nothing scientific but I think the oil seal was so old that the Seal Doctor tore into the oil seal material. Seal Mate or facsimile might have worked (bottom pic). The Seal Doctor is stiffer and thicker.
« Last Edit: January 14, 2019, 06:40:06 AM by RonW » Logged
Bagger John - #3785
« Reply #7 on: January 14, 2019, 07:05:16 AM »
Mine went right in - both sides.
2 years operational time and no leaks.
RonW
Newport Beach
« Reply #8 on: January 14, 2019, 08:17:25 AM »
I'm glad for you that there wasn't any fitment issues. Few years ago, it took me two hours getting an oil seal into a fork on my other bike. I forget if it was All Balls oil seal, but still the same issue. I don't have a garage. I only have a basement parking stall to work on the bike, so I don't have the option of finishing up the bike later in the week. The experience left me paranoid probably why I'm inclined to heed the advice of forum member at least with this repair.
Grandpot
Fort Mill, South Carolina
« Reply #9 on: January 14, 2019, 08:17:58 AM »
I used PVC pipe.  Slit it to fit around the fork tube.
Bagger John - #3785
« Reply #10 on: January 14, 2019, 09:15:26 AM »
...I don't have a garage. I only have a basement parking stall to work on the bike, so I don't have the option of finishing up the bike later in the week...
I rebuilt 3 sets of Valkyrie forks - including removal and replacement on the bike - in 7 hours during a Tech Session hosted by the Ohio VRCC several years back.
We used an improvised PVC pipe seal driver there, and I've since bought the Honda tool.
In two cases, failure (or delay) wasn't an option either. One of the members rode over 100mi to attend and I wasn't going to leave him stranded. That said...
Lube and cleanliness are your friends.
In all the years I've been wrenching scooters (since the early 80s) both professionally and in a D-I-Y capability, I've never had a seal replacement problem if all the parts are carefully cleaned and properly lubricated prior to inserting the new seal...regardless of brand. This includes Harleys, Valkyries, many other street bikes, a gazillion dirt bikes of various manufacture...normal forks and inverted forks alike.
In the case of my Tourer's forks, the All Balls seals went in no differently than OEMs do - and on the occasion I've had to remove this brand from a fork tube they come out with equal ease. Next time I have a pair of new OEMs and a pair of new AB seals side by side I'll throw a caliper on them and post the differences. I'm speculating no more than .002" variance.
« Last Edit: January 14, 2019, 09:18:14 AM by Bagger John - #3785 » Logged
RonW
Newport Beach
« Reply #11 on: January 14, 2019, 09:27:42 AM »
John, free country.
Anyways, for this fork seal replacement, I rented a fork seal driver for $8/day. It was so easy driving in the oil seal, the ergonomics of it. The driver has a taper so you don't damage the inner section of the oil seal. I wasn't aware off this feature. Guess you could file a taper on the pvc driver.
