November 14, 2025, 05:20:39 AM *
Author Topic: TBR 6/6 pipes  (Read 967 times)
spartacus1215
« on: January 12, 2019, 08:49:20 AM »
Ok guys, here’s an update. It turns out I had really bad gas in the tank. Drained it and filled with fresh gas and it’s running great except that the idle is 2200. I’m thinking that when I rebuilt the carbs I forgot that I had TBR 6/6 pipes and they need non-stock jets. I put oem jets in when I rebuilt them. So... does anyone know what jets I should put in for my pipes and where I can get them?
« Reply #1 on: January 12, 2019, 08:55:56 AM »
... I forgot that I had TBR 6/6 pipes and they need non-stock jets. ...
They don't.
Bigwolf
Cookeville, TN
« Reply #2 on: January 12, 2019, 09:34:29 AM »
There is a small plastic knob just in front of number 3 carb.  It is back in by the linkage so you might have to get down and look closely back in there.  That is the idle setting screw.  Adjust it till your idle comes down to spec.  900 - 1000 rpm
Two Brothers runs fine with Orem jets.
spartacus1215
« Reply #3 on: January 12, 2019, 10:40:39 AM »
Thanks! Is there a recommended setting for the jets?  I may not have them adjusted right. I think I just seated them and didn’t back them out al all. Sometimes I do things in a rush and regret afterwards
pancho
Bonanza Arkansas
« Reply #4 on: January 12, 2019, 01:34:53 PM »
I hope messing around with your carburetors doesn't turn out to be one of those things...  If you are talking about the pilot screws, two and a quarter turns out should get you in the ball park to get started.
spartacus1215
« Reply #5 on: January 12, 2019, 01:48:52 PM »
Thank you!
