spartacus1215
« on: January 12, 2019, 12:49:32 PM » |
Hi guys, it’s bob again. I’m a struggling newbie even tho I’ve had my ‘98 std since new. My bike was impacted by Hurricane Irma last year and I’ve finally got her almost back to herself. Problem is the carb setting and idle. I’ve read numerous posts but I’m confused. Is there a single pilot screw or are there 6? Is the pilot accessible while the bike is running so I can adjust or do I have to take the beast apart again? I know about the idle control screw, but is that the same as the pilot screw? Sorry for my ignorance, I’m not in a position to pay to have these adjustments made so I have to struggle thru it. Any and all guidance is greatly appreciated! Thank you!
« Reply #1 on: January 12, 2019, 12:56:15 PM » |
The pilot screw is on each carb. They face down right behind the chrome intake runner. It takes a special tool to make adjustments. Go on Motion Pros website to get a cheap one. The Honda OEM tool is quite expensive. Set them with the engine off and cool. Close them (clockwise) lightly and open them 2 full turns to start. Lots of people open 2 1/4 to 2 1/2 turns but this usually makes them run a bit rich, but might yield more HP (less MPGs).
spartacus1215
« Reply #2 on: January 12, 2019, 01:04:43 PM » |
Thank you!!!!!!!!!
spartacus1215
« Reply #3 on: January 12, 2019, 01:08:33 PM » |
Is the tool you refer to called a 90’ carb tool with bits? Around 70$?
spartacus1215
« Reply #4 on: January 12, 2019, 01:16:19 PM » |
I just found a pilot screw adjusting tool on the motion pro site. I am guessing this is the tool you are referring to?
pancho
« Reply #5 on: January 12, 2019, 03:55:40 PM » |
Don't know what you are looking at Bob, our carbs use a "D" shape bit. If you don't have one already, it's unlikely you seated the pilot screws.
If you had the carburetors off, I wonder if you got all the boots back on correctly. Air leaks could be causing idling problems and should be checked out first,, it is easy to get them on with the backside folded up out of place causing air leaks. A dental mirror and flashlight help to see if they are on incorrectly.
« Last Edit: January 12, 2019, 04:07:58 PM by pancho »
WintrSol
« Reply #6 on: January 12, 2019, 04:40:17 PM » |
What is your approximate location? If you'll note, many of the high post count members have their general location in their signature, or under the avatar. You never know - another member may be close enough, and inclined, to drop by and help.
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
« Reply #7 on: January 12, 2019, 06:14:25 PM » |
Pilot screw
No. But thanks for asking.
« Reply #8 on: January 12, 2019, 07:04:08 PM » |
jbrooks
« Reply #9 on: January 13, 2019, 08:22:54 AM » |
WintrSol
« Reply #10 on: January 13, 2019, 09:15:58 AM » |
While that tool works, if you don't have small hands, it can result in burns.  I much prefer the Motion Pro version, over that stubby one, or the flexible type.
pancho
« Reply #11 on: January 13, 2019, 09:20:24 AM » |
Is there clearance for the motion pro tool to access the pilot screws on all six carbs?
« Reply #12 on: January 13, 2019, 09:46:54 AM » |
this is the best honda tool to get, it was org listed for the cbr900.
it has a flexible spring head. been using it for yrs.
07MMA-MT3010B WRENCH PILOT SCREW
prices lately are from $70-100. so shop around.
« Reply #13 on: January 13, 2019, 10:00:10 AM » |
WintrSol
« Reply #14 on: January 13, 2019, 01:09:34 PM » |
You have to hold your mouth right for some, but yes, it will reach all six.
pancho
« Reply #15 on: January 13, 2019, 03:03:02 PM » |
You have to hold your mouth right for some, but yes, it will reach all six.  Thanks, so if you were only going to have one, which would it be, motion pro type or spring type?
WintrSol
« Reply #16 on: January 13, 2019, 06:12:45 PM » |
You have to hold your mouth right for some, but yes, it will reach all six.  Thanks, so if you were only going to have one, which would it be, motion pro type or spring type? Actually, I have all three. I started with the stubby one, then the spring type, and finally the motion pro. I use the stubby one to set the initial position, and the MP when it is warmed up. I found the spring type to hard to get set, but that may just be due to my stiff fingers.
« Last Edit: January 13, 2019, 06:14:48 PM by WintrSol »
pancho
« Reply #17 on: January 14, 2019, 03:02:51 AM » |
Hmmm,, I've had stubby ones since I've had machines that required it and was always able to do what I wanted, but I think it's time to make it easier and upgrade. If the motion pro type can access all six on our bikes, that is what I'll go with. After seeing the feedback on the knockoffs, it seems that it pays to go with the original Motion Pro tool.
WintrSol
« Reply #18 on: January 14, 2019, 12:13:09 PM » |
It helps to have a small mirror 'on a stick', like a dental mirror, to see where the flat of the D is, so you can preset the tool for the angle you will need. At least, you will know it it close, and won't have to go hunting for it.
« Reply #19 on: January 14, 2019, 02:08:27 PM » |
« Reply #20 on: January 14, 2019, 02:23:33 PM » |
Last time I pulled the carbs, years ago, I used a Dremel tool to cut a slot in each pilot screw thereby doing away with the need for the special shaped "D" socket tool. I can now just slip a common straight blade tip into the tool and don't have to struggle to find the flat side....which always seemed to get rounded off anyway.
spartacus1215
« Reply #21 on: January 14, 2019, 06:26:10 PM » |
Update. Disconnected the throttle cables to try to get a fresh start on sorting out my high idle issue. With no cables my base idle is 2200. Obviously way too high. What can cause this? Do I need to adjust the pilot screws? I already checked the floats and the jets. Once again all advice is welcome and will be followed. I bought the tool to adjust the pilots and it should arrive Tuesday. Thx everyone
« Reply #22 on: January 14, 2019, 06:30:34 PM » |
idle adjustment or very bad vacuum leak.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #23 on: January 15, 2019, 08:30:35 AM » |
Have seen some use carb spray, wd40 and I have used small propane tank with hose shoved on end to find leaks, then I would check idle adjustment if its determined that no vacuum leak exists.
Michael
1997 GL1500C - Black 1997 GL1500C - Purple 1997 GL1500C - Bumble Bee 1998 GL1500C - Blue and Cream
RonW
« Reply #24 on: January 15, 2019, 12:12:24 PM » |
Wasn't there a reference pilot screw which the other carbs are set to? spartacus1215, what gauges are you using?
2000 Valkyrie Tourer
WintrSol
« Reply #25 on: January 15, 2019, 12:18:06 PM » |
I believe you are thinking of the reference throttle, to which the other five are sync'd.
« Last Edit: January 15, 2019, 02:58:07 PM by WintrSol »
RonW
« Reply #26 on: January 15, 2019, 12:21:26 PM » |
Oh.
spartacus1215
« Reply #27 on: January 15, 2019, 05:02:49 PM » |
I have not “synched” the carbs. I replaced the gaskets, jets, and cleaned everything else. I also did the fuel rail job. The engine sounds great but it’s just idling too high. With the throttle cables off its base idle is 2200. The actual throttle linkage seems to not want to go all the way back to its stop. I can manually push it back to its stop and get the idle to drop but not all the way to 900 or so.
« Reply #28 on: January 15, 2019, 05:05:31 PM » |
the thru bolts that hold the carbs together might be too tight. back off on the nuts see if that helps.
« Reply #29 on: January 15, 2019, 05:07:01 PM » |
Silly question.
Are you using the idle knob? Located right side sorta around the front two carbs and tucked away if memory serves me right.
« Reply #30 on: January 15, 2019, 05:09:00 PM » |
« Reply #31 on: January 15, 2019, 07:46:58 PM » |
It is easy to turn with one finger.Maybe 15 years ago it was easy to turn, and I have short fingers. What's easy to do is burn one (or more fingers/knuckles). Thin gloves give you a false sense of well being. You still get burned, it just takes a few seconds longer. Ideally, you set idle when the bike is warmed up.... but it's more than warm. When you know it needs turned up a bit, you can estimate it when cold, but then you have to remember to see how your cold estimate turned out once it's hot. 900 (per manual) is OK.... so is 1000. (unless you spend your day idling at lights) My bikes idle low for longer than just warm up (they need a minimum 15-20 minute ride to settle into a stable idle), and my Kuryakyn Volt meter shows red (not charging well or at all) on low idle when I knock the choke off soon after startup. So I like a 1K idle.
« Last Edit: January 15, 2019, 07:48:47 PM by Jess from VA »
« Reply #32 on: January 15, 2019, 08:02:14 PM » |
You want to adjust the idle knob while running, just stick a screwdriver in there and push against one of the ridges on the knob. It will turn in either direction depending on where and how you push with the screwdriver. Can't remember the last time I turned it with my fingers, I'm allergic to pain.
Forge
« Reply #33 on: January 16, 2019, 10:26:26 AM » |
Verify that your link lever is installed correctly or isn’t in a bind. It’s the lever that links both sides of your carbs.
